AVS › AVS Forum › Audio › 2 Channel Audio › Integrated Digital Amp with Wifi and USB?
post #1 of 9
Looking for an integrated stereo amp with:
- Wifi/DLNA support
- USB input for connecting USB stick or harddrive
- must support 96/24 WAV/FLAC
Do not want an AVR.
What's out there that can do this, or do I need a 2 box soln?
post #2 of 9
I think the wifi might be the biggest roadblock in your list of demands
also, what's your rough budget? I cant imagine the ideal product being super affordable
post #3 of 9
Hello Brian,
I'm looking for the same solution. I believe you/we will end up buying the Integrated Amplifier + Extra gear in order to have the USB input, Wireless/DLNA....
post #4 of 9
post #5 of 9
Originally Posted by Clarion View Post
Naim UnitiQute
http://www.naimaudio.com/hifi-product-range/579
this device only has an analog USB connection, aka the signal isn't fed through the Naim's internal dac. the front input doubles as a 3.5 toslink, and there are coax and optical inputs in the back, but no digital USB. this may or may not suffice for the OP.
post #6 of 9
The Onkyo TX-8050 has WiFi & USB which plays from a thumb drive (mass storage) but only plays MP3 - no WAV or FLAC files. It's also a receiver.
post #7 of 9
Get any simple stereo amp, and add Squeezebox touch (I can't call that tiny device a box). You even can use pure power amp, for that purpose, if media player is your only source.
post #8 of 9
- Wifi/DLNA support
Do not want an AVR.
There should be no problem finding a Blu Ray player with these features, except for the 24/96 wav/flac weirdness. You are probably in your own world for that one - get a cheap laptop for that.
post #9 of 9
With BD player you also need monitor to see menus. Device with touch screen is much better. Cheap laptop needs external DAC, and is likely more expensive then Logitech device.
