Hi,
Yesterday i calibrate my 95es,according to lovingdvd suggestion with Iris on Auto 1.
I adjusted the white level and my greyscale is almost perfect,a little off only at 10%(red).
Gamma was set to OFF,and and the value is now on 2.33.
RCP was set to OFF and in this way is practically almost perfect on all saturation check (25,50,75 and 100%). Only Green at 100% is a little over saturated ,but not by much,only a little.What is funny is,now after greyscale adjustment i have 47cd/m2
.In the first day when i made the measurement i was on 44,7cd/m2(maybe i was doing wrong with something).
Practically if you are OK with gamma between 2.2 and 2,45, you don't have to make many adjustments to have a very, very good picture..
I have 43 Hours on my lamp in low mode.
.In the first day when i made the measurement i was on 44,7cd/m2(maybe i was doing wrong with something).Practically if you are OK with gamma between 2.2 and 2,45, you don't have to make many adjustments to have a very, very good picture..
