Guys, I have a couple of questions, that I think only you pros can answer.
Little background.
I thow a 92" picture from ~9ft, PJ is almost at max zoom.
I dont have a batcave.
Source is Bluray from my HTPC
KMplayer-Madvr renderer, LAV decoder.
Nvidia GFX card
I do want the darkest black out of this projector. When calibrating brightness, to be able to see level 17, I have to pump the brightness to 55~. This also brighteners the ref black(16) in the whole image. And strangely, level 17 looks darker than 16?
So right now I use 53. I can barely see 18 flashing, but 17 is the same as 16.
They way I see it, I would like a brightness of 48-49, which gives the darkest black the PJ can produce, but still be able to see the slightest details in dark scenes.
For reference I use "Casino Royale" at 00:01:16, the scene where the bad guy turns around and Bond is sitting on the chair. I look for Bonds tie and collar.
Then I started to mess with the gamma presets.
Gamma 1 gave me almost what I wanted. Bonds details in the scene where visible, had brightness at 49, but then changed to Cinema 1 to see the difference on a bright scene with colors, and wow, Cinema 1 (Brightness 50, Gamma 9) )was way better, not so flat as with Gamma 1), but, the details disappeared.
So am I totally nuts? and want something that is not possible, or do I need to tweak more.
Right now Im settled with Cinema 1, Iris 1, Brightness 53, Contrast 89, Gamma 9, Blk level -1.
Great picture overall, I see bonds details but I wonder if its possible to do that with a lower brightness, so I can get the darkest black of this PJ.
Professional calibration to get a custom gamma curve maybe?
