Originally Posted by
coppertop
simple answer...SUB EQ. Worth $300 on it's own. Plus 9 channel amp...and a bunch else. There is some advantages to the 818 like the thumbnail source preview. But for $300, the SUB EQ and 9 channel amps are the key differences.
How would you add (hook up) 4 subwoofers to the 3009.
2 SVS PB12-NSD subs (ported) and 2 BIC America F12 subs (sealed).
Because of my small home theater, the only place that I can put all 4 subs is against the front wall.
The PB12's are in each corner and the F12's are located closer to the center of the wall, spaced equally apart.
Again all four subwoofers are spaced equally across the front wall.
Edited by coolcat4843 - 7/19/12 at 12:08pm
