AVS › AVS Forum › Display Devices › Display Calibration › Focus Test Pattern
Focus Test Pattern
post #1 of 11
I was just wondering does anyone know where I can find this test pattern. I know a signal generator will produce this, but can I find this on a calibration disc?
post #2 of 11
Oh well, it was worth a try.
post #3 of 11
Give it a chance man.. it's a forum, not Google!
post #4 of 11
Yes. Which disc format do you want?
post #5 of 11
Blu-ray preferably, it just needs to be 1920 x 1080. I'm trying to get my focus dialed in and the grid pattern on my projector is really hard to look at for a long period of time.
post #6 of 11
Not the exact one but a great site. Also there are very good patterns on the AVS S&M, and DVE discs... have you tried those?
Also Calman has a good pattern generator on their download page.
http://www.walvisions.com/statics.html
post #7 of 11
I use the AVS 709 disc for focus. In the misc patterns under resolution the second pattern (single pixel cross I think) works great for very fine focus.
post #8 of 11
I haven't seen that old pattern or an 'Indian Head' HD version of it in 1080p. There are similar patterns available from the following:
'Digital Video Essentials: HD Basics' Blu-ray Disc- see: "SMPTE RP-133 Resolution Chart" in the "Advanced Video Patterns" section (also available on 'DVE Professional' WMV HD).
'DisplayMate for Windows' PC Program- see: "Master Test Pattern" in the index.
As mentioned, there are alternate patterns specifically designed for focus and/or resolution tests in other HD test programs. They may be easier to your eyes.
post #9 of 11
Thanks guys, I will give those a try.
post #10 of 11
I'm not sure how much resolution you need, but the indian head on myTvTestDisc might work for you. You can download it off their .com web site.
post #11 of 11
If your player has a USB input and can view still images here is the NEC test patterns.
lots of stuff in here.
https://files.me.com/nashou.66/j9cf1p
Athanasios
