I'm in the market for a new IP thermostat, but I'm having trouble deciding which way to go. I currently have the Filtrete 3M-50, which I would consider a "budget" IP thermostat. I love having remote access, but I'm fed up with the operation of this tstat (I won't go into the details - that's a rant for another thread).
I've narrowed down the replacement options to two - the Honeywell Prestige HD with Redlink Gateway, and the Ecobee. There seem to be pros and cons for each.
Honeywell Pros:
- Easy to install.
- Should be reliable (seems like 90% of all tstats are Honeywell).
- Comes with outdoor temperature sensor.
Cons:
- Separate Redlink gateway needed for internet access.
- Tstat itself doesn't seem to "use" the internet for weather, etc.
Ecobee Pros:
- Excellent GUI.
- Wi-fi built into the tstat.
- Weather forecast displayed on the touchscreen.
- Cheaper (compared to the Honeywell).
Cons:
- More complicated to install (with the equipment interface).
- Reliability?
My other concern with both units is the web portal. Currently, both are free, but Ecobee used to charge for this, so I'm guessing that could come back. Also, the remote interface is dependent on the company keeping the servers running. I'm guessing Honeywell can afford to lose money on something like this, but Ecobee is a smaller company. If they go out of business, there goes remote access.
At this point, I'm leaning toward the Ecobee. The unit is really slick, and the remote interface seems to work very well. That said, I haven't seen a demo of the Honeywell remote interface.
Does anyone have experience with either of these units, or both? I'd love to hear feedback from people who have lived with either of these.
I've also considered the just announced Nest learning tstat, but I'm not quite sold yet. Sure is sexy looking, though...
Thanks for any opinions.
Honeywell Pros:
- Easy to install.
Cons:
Ecobee Pros:
- Excellent GUI.
Cons:
- Reliability?
