AVS › AVS Forum › Other Areas of Interest › What's Your System Configuration › NezFF's Media Room
NezFF's Media Room - Page 8
post #211 of 285
I have five seats. The plan was to have one row of two, then one row of three on a riser behind, just never got around to it, plus we dont really need it.
post #212 of 285
Just saw your updates, wow I can't believe you sold the Klipsches. I hope you enjoy the new speakers, sorry to lose a fellow Klipsch owner.
post #213 of 285
I'd like to commend you on your image contributions. I've been involved both professionally, and as an enthusiast, in photography for over forty years. This includes both cinema-photography and still pictures. Still photography,... is all about the proper use of light. Rarely, around AVS, does one encounter well illuminated pictures that accompany thread contributions. Your previous image of the new center channel is a solid example of what I'm referring to, nice DOF as well,......sweet.
All too often images are plain and flat, due to the use of direct flash that is so harsh it destroys and washes out any textural component to the subject. I do it occasionally too w/my small point and shoot. But everyone always inquires about tips,.... I always tell my friends and family the same things,...I explain it's counter intuitive, for people pics it's flash outdoor during the day/bright sun, no flash indoors. Certainly there's many exceptions, but anyway, nice job.
Good luck
post #214 of 285
post #215 of 285
Hi! Can you tell me, what Speakers you use in the front and center ? B&C 10-12" ?? Witch ?
And compression driver DE250 with ME45 horn ?
What is the crossover frekvency, are there any compensation in te crossover ?
post #216 of 285
Elemental Designs Cinema 12s.
DE250 compression drivers
Eminence kappa pro 12A woofers
Eminence makes the horn also.
post #217 of 285
Got the room back in order somewhat. Still undecided where I want my surrounds considering they are direct radiAting towers and not surrounds persay.
post #218 of 285
Look into some Triad inwall or OnWall silver surrounds. I bet they would sound great in that room, then you wouldn't have to worry about floor space anymore.
post #219 of 285
Why would I want to do that when I just spent money on a whole custom setup. Lol
post #220 of 285
Absolutely beautiful, well done pal...
post #221 of 285
Thank you sir.
post #222 of 285
Well, I did some tests yesterday with placement of the subs. I did the sub crawl and found some pretty weird results in my room. I found that between my seating and the front of the room the bass was more pronounced. I also found that behind my seating about 5-6 feet and on the right and left walls the bass was the best. This is a very odd spot for my subs considering they have always been up front. Aesthetically they look best up front but I have a null or void about 8-12 feet in front of them. The bass is just not the best it can be where they were at. Obviously my room is doing some crazy things with the lower frequencies.
My main concern is that even though they sound the best in the back, they are so large, that they might not "look" the best there. Again I'm open to the best sound of course but still want the best look. I plan on taking some pics of the room to see what you guys think.
post #223 of 285
How did you move the subs to your listening position? Those things are HEAVY! Did you do the crawl test with music or test tones? Did you measure with a SPL meter or microphone, or just listen? I'm thinking of embarking on a similar journey with my smaller SVS PB12-NSD and was wondering how you did the crawl. That said, I would face the same dilemna in terms of placement -- aesthetics vs. sound -- but I still want to know whether I'm sitting in null or a void!
post #224 of 285
I took the feet off of them so they slide on the carpet fairly well.
I looped a 40hz test tone and crawled around the room. I played a son also and cut the speakers off and listened to just the subs.
post #225 of 285
Nice updates man.
post #226 of 285
Make sure the feet aren't covering holes. With Submersives the feet screw in pretty far, and Mark said they need to be in or there will be leaks. I don't know if eD has a similar design with their feet.
BTW, you have PM. You may already know everything I said but I just wanted to make sure.
post #227 of 285
Thanks bro. The feet screw in to screws that are set into the cabinet. I might ask Alex tomorrow.
post #228 of 285
tried them facing the wall this morning. Not too bad of a look, and pretty nice in the sound department.
post #229 of 285
excuse the white wires, trying to figure out where I want my surrounds before I make a final cut.
post #230 of 285
Awesome thread man. Where in cajun country are you from if you dont mind me asking? I am about to buy a house in Mandeville that has a bonus room almost exactly like yours, but of course the wife wants to make it a bedroom/playroom, but I like your idea much, much better!
post #231 of 285
Thanks. Alexandria.
post #232 of 285
How you liking the center?
post #233 of 285
Im liking so far. I have been playing some music and movie passages through it and the surrounds to break them in a tad more the last couple days.
post #234 of 285
Forget all the gadgets, I just want the room! They just built two new homes down the street and they appear to have media rooms over the garage. Seems to be the new trend in homes, well around here. I think it is time to move. Nice set up, happy tinkering.
post #235 of 285
When I built this house about 2 years ago, I made sure the plans had a bonus room. Lol
Thanks for the kind comments.
post #236 of 285
Tried this out today, sounds good. Still need to measure.
post #237 of 285
At first glance I thought you added wides lol
post #238 of 285
lol. Ill probably stay with my 5.2 for a while.
post #239 of 285
No 7?
post #240 of 285
No 7?
If I would have a DSX capable AVR or pre/pro I would definitely go for Wides. Last time Chris K. on FB explained while panning for our ears works fine up front from Left to Center to Right, it is not possible to have the same seamless panning effect on the sides, i.e. Left to Left Surround and Right to Right Surround and that led Audyssey to develop DSX, especially for Wides. When Wide speakers are placed carefully the effect of DSX for side panning is a kinda magic.
Just need two more speakers and a little cabling! Still not interested?
