Do they have a "wall away" feature like the berklines?
Yes, you need about 4-5 inches from the wall. So they will go back about 4-5" in to your back "section". I can get you the exact # tomorrow.
Can I take an arm off and make them how I want? Let's say a loveseat in the middle?
The following pieces are available:
2-Arm Recliner with Power |O|
2-Arm Recliner with Power, Shiatsu Massage, |O|
LF 1-Arm Recliner with Power |O
RF 1-Arm Recliner with Power O|
Wedge table \\/
I was also wondering about the loveseat configuration. I was considering the Row Ones but did not see a loveseat config. I want a curved row of 3 in the front and row of 4 with loveseat middle in the back row.
You can build quite a few configurations, but the only way a curved row of three can be done is do use three 2-arm chairs and two wedge tables because there is no armless chair at this time:
|O|\\/|O|\\/|O| (this setup is probably wider than you need it to be)
|O|OO|O| (uses 2 LF 1-arm recliners and 2 RF 1-arm Recliners)
|O|O|O| (uses 1 LF 1-arm recliner, 1 2-arm recliner and 1 RF 1-arm recliner)
I hope this answers all of the questions.
