I've had my NX70 for two days after saving $$ for months in great anticipation. I also have an HDR-CX550V which I love.
My tests of the NX70 over the last two days reveal some disturbing problems. They are so bad I might return the camera - but the problem is there are no other viable alternatives in this price range from Sony, Canon or Panasonic that have the features I want. I'm freaking out, man!
I'm working on creating a video that shows the problems , and will try to post it tonight. Until, then here are descriptions of some of the problems, I'm wondering if anyone else is also experiencing them. I'd really appreciate feedback from other NX70 owners.
In low-light, when the gain is anywhere above 12dB and Active Steady Shot is engaged, there is a pulsating effect in the video, about 1 to 2 times a second, where the image will blur. Blur, sharp, blur, over and over again. Does not happen with my HDR-CX550V when shooting the same subject at the same time. (BTW, the 550V has slightly better low-light performance) It reminds me of Auto Focus hunting, but it also seems to happen when focusing manually. The effect is so horrible that it rendered footage of my cat Max pretty much unviewable. The problem seems worse when the camera is pointed at subjects with fine detail - the hair on the cat, cloth, books in a bookshelf, etc - but it is there on anything, just harder to notice. It happens if the cam is on a tripod or is hand-held. It happens in HD-FX in both 60p and 60i. The problem is NOT evident on the LCD screen while shooting, but if you export the video to a computer, you notice it right away. It is also there if I plug in via HDMI to a TV. I noticed it immediately in the first vids I watched.
The problem is horrible, and unexpected. I've never seen anything like it on my CX550V.
If I turn off the Active Steady Shot and just go with Optical (standard), it is not as bad but it is still there.
In general the Steady Shot is not nearly as good as the 550V - this was also mentioned in reviews of the CX700V such as this one:
http://www.camcorderinfo.com/content...Comparison.htm
(the NX70 seems to have the same internal "engine" as the CX700V, as far as I can tell)
The other thing I noticed is the color is muted compared to my CX550V - it makes me wish there was a "saturation" control that I could turn up. The sky is a duller, more navy blue, instead of the beautiful cobalt blue I get from the CX550V. The auto white balance is not nearly as accurate.
In general, the NX70 has a terrible picture compared to the CX550V! This is unexpected and disturbing. The clock in ticking on the return window - need some feedback soon. I have not yet called Sony support, but will do so as soon as I have a video posted they can watch.
Any comments greatly appreciated!
Worried and sad,
Steve
Worried and sad,
Steve
I think you have hit the nail on the head.
