FIOS/Moca question
post #1 of 10
I'm getting standalone FIOS internet (no TV service) installed next week, and finally cutting the Comcast cord. I'll be getting 25/25 service, and based on what I've read, I expect that they will plug the main FIOS box into the coax terminal outside the house, which should then go into their router.
I'm wondering if I'll be able to utilize additional MoCA devices connected to the coax system in other rooms, to send ethernet around my house? Are there any caveats to this, or any limits on the number of rooms I can send it to? I'd like to eventually get three separate rooms set up. And assuming I don't have a hinky coax system, what practical speeds can I expect?
post #2 of 10
You could have the Tech do a Cat5 Ethernet Install if you want.
Yes...
Here's some information on MoCA
http://www.mocalliance.org/industry/...d_products.php
http://en.wikipedia.org/wiki/Multime...iance#MoCA_1.1
Essentially up to 16 devices - as I believe a majority of devices are still MoCA 1.1
You can hook up separate rooms as well.
Here's a few devices for sale:
http://www.provantage.com/scripts/se...x=0&Submit.y=0
http://www.amazon.com/D-Link-DXN-221...0504300&sr=8-4
Speeds are "up to 100Mb" --
http://www.tomshardware.com/reviews/...ng,2470-8.html
You should expect between 65Mb/s to 90Mb/s
MoCA does add some latency too..
http://www.tomshardware.com/reviews/...g,2470-10.html
post #3 of 10
thanks for the info, chomper87 - I didn't realize that Tom's had done a writeup on MOCA. I guess my Google Fu is not as strong as I thought.
post #4 of 10
Have the tech run a cat6 or 5e to the router. In case you ever want to use your own router, DIY or whatever, its just a better setup.
post #5 of 10
Another rec for using ethernet instead of Moca. I've had FIOS since 2007, and followed a lot of forums. People have had lots of problems with FIOS and Moca. I don't know if they are all worked out yet, but I don't see the big advantage. A tiny fraction of devices work with Moca, whereas ethernet has broad support.
post #6 of 10
MoCA is VZs default choice. A big reason is probably because Homes, Apartments, etc are likely to already have Coaxial cable installed. So they can simply use the existing cables. Save on install time meaning more installs can be done. Chances are the "majority" of consumers probably don't care or know any better.
Plus the Coax cable is useful for their TV services. The can offer two services over the using the built-in Coax cable - it's pretty enticing from their perspective. They can also have proprietary devices made or have custom firmware made such as their Actiontec and Westell Routers and STBs where they will happily work with together over MoCA and also allow VZs Cable TV signal
post #7 of 10
But yeah - the advantages of MoCA tend to favor VZ rather than the more technical consumer.
post #8 of 10
My problem is that the house is not wired for Ethernet - I've thought about it, but our house is a bit tricky for a full home Ethernet drop, since we have a very small crawlspace, and vaulted ceilings with no attic space.
My plan was to run a MOCA bridge in each room, plugged into a switch or router, to potentially support multiple devices in each room. I'd like each device to have access to my home server, which will hang off the main router.
Is this even feasible? I have no idea how well MOCA supports DHCP or UPnP.
post #9 of 10
DHCP and UPnP will work just fine over MoCA. MoCA itself doesn't limit features - you can use it almost exactly the same as Ethernet.
The only thing to look for is not to use any Coax Signal Boosters or Amplifiers. Use plain old Coax splitters only. VZ should do this all for you though.
post #10 of 10
Have you actually been able to make uPnP work over a MOCA bridge on FIOS? I can't. If so, please advise how you did it. I have a second router attached to the primary via MOCA bridge (actiontec) but XBox attached to it only recognizes my PC when on the same router. Everything I have found via google says the problem is that UPnP doesn't work over a MOCA bridge. A recent UPnP standard update is supposed to fix this but doesn't help my XBox. I don't run Ethernet for many of the same reasons as the OP. Ideas for a workaround?
