Control of AV components.
post #1 of 14
Hi everybody,
Right now all of components are below my screen. I am going to a dedicated room and the components will now be in wall behind the seating area.
How are you guys controlling all of your AV components that are behind the seating area or in another room?
Thanks for any help in advance.
post #2 of 14
Lots of IR repeater options which are easy and cheap...
post #3 of 14
Thanks for the reply. I have a Harmony IR repeater. But the cable length is nowhere near what I would need for placement. Just trying to find out what others are using.
post #4 of 14
I'm not familiar with that model, but you should have no problems with most options running longer cables to meet your needs. For example, check out the instructions on this one:
http://www.buffaloelectronics.com/infrared/ir350.htm
post #5 of 14
This is working nicely for my needs (eqpt rack outside of HT)
http://www.amazon.com/dp/B002IC0YL8/...SIN=B002IC0YL8
post #6 of 14
In Michael Jackson's HT he used to have a console (captain chair) in the sweet spot where he controls everything.
post #7 of 14
Unfortunately - I don't have a command deck or a crew that listens to me.
post #8 of 14
I use a Harmony 880 IR remote, and a HotLink XL Cat5 IR repeater:
http://www.amazon.com/Hot-Link-CAT-5...0531375&sr=1-1
post #9 of 14
I have used IR repeaters and I moved to RF. I like RF much better. Never have to worry about pointing the remote. Also consider Ethernet control if you are getting new equipment.
post #10 of 14
That looks promising. I tried to google the direction but came up with nothing. Does it come with the Cat5 cable and how long was it.
Sorry for the questions .
post #11 of 14
I don't think it came with a cat5 cable, or if it did, it was very short, so not useful. I used a spare cat5 cable I had laying around, connected to cat5 wiring and wall plate connectors that I ran between behind my screen wall and the equipment room.
Instructions:
http://www.hot-link.com/pages/produc...id=1&mrchid=11
http://www.hot-link.com/dl.cgi/12041...kxlinstruc.pdf
post #12 of 14
Thanks. I will research that a little also.
Instructions:
Thanks - I appreciate the help.
post #13 of 14
If you have an iPad, you could check out iRule. There's a huge thread here on it and many people really are enjoying the app.
post #14 of 14
Just another vote for the Hot Link XL repeater over CAT5. On the "front of the room" side, it has a sensor and an acknowledgement LED. I put both behind an AT screen and the blue confirmation LED is just barely visible through the screen if you are looking for it. It then has a nice six-head IR blaster on the other end.
I ended up getting the Harmony One and the repeater instead of the 900 because I heard Logitech removed sequences from the 900. They are not critical, but I like having the lights turn off when I hit play, and them turn on to 20% brightness when I hit pause. It's simple, but makes me smile every time.
