AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Technical Issue with HDTV screen
post #1 of 4
I'll have to edit this later when I have a picture of my tv, but basically it looks like a normal screen with colorful lines on the side that stay there and do not move, fade or anything else. It also has what looks like something hit it and cracked the glass, but there is no crack that I can feel so it might be internal. What can I do? Do I have to fix the logic board and what it says on the youtube comments? It's a Westinghouse 40" 1080 HDTV that I bought 1 yr. ago.
post #2 of 4
Thread moved to proper display forum.
post #3 of 4
Look at the link, about 3/4 down. If that's what your screen looks like they say its caused by a defective tab.
http://www.lcdparts.net/howto/symptom.aspx
post #4 of 4
Very similar, but I also have shorter, rainbow colored lines. Hopefully you can see this:
