I have an Antennacraft HBU22 antenna mounted in our attic. The coax goes from the antenna into a 4-way splitter in our structured wiring panel. It's roughly 50 feet or so of cable for each run from the antenna to the TV. No amps, preamps, or filters are currently installed.
Here's our tvfool data.
A few of the channels have occasional problems with the signal dropping low enough that the picture breaks up or completely disappears. In order of frequency of occurrence: KVIE (9), KTXL (40), KXTV (10), and KOVR (25). (I'm not sure if I've noticed problems with KOVR this Fall yet, but in the past, I definitely have.)
Is there something simple I might try to help alleviate these problems? Or should I just be happy that an attic-mounted antenna can get these as well as it does?
Ken
Ken
A larger antenna might indeed work. But I'm not entirely convinced that the problem is multipath and not signal strength.
