AVS › AVS Forum › A/V Control & Automation › Home A/V Distribution › Is ghosting a fault of the cable being used?
post #1 of 2
I bought a component cable for my xbox running xbmc and i noticed some ghosting, is that a fault of the cable? It makes a shadow that is visible and is quite annoying in dark scenes
post #2 of 2
It can be. It can also be the fault of the electronics at either end of the cable, or a combination.
  Back to Forum: Home A/V Distribution
