Originally Posted by
swolfcg
Analog as in RCA? I would have thought Optical would be better than Analog. or is Optical Digital considered analog.
Yes, analog as in RCA, but not the digital coax. The analog are the 7.1 RCA outputs and not the single digital RCA out. Digital optical/coax (not HDMI) is indeed better than analog until you get to the formats that have digital copyright crap imposed on them.
swolfcg
Those guys over in the Panny Blu Ray thread are stating that you only need one HDMI cable, between your Blu Ray and Rcv, even if you don't have a ARC capable device. My tv is not ARC compatible, but I'm only running video to it. So no issue with just one HDMI out cable to it from the rcv.
But those who don't have a ARC capable Rcvr will probably have to run two cables from the rcr and blu ray player.
I think you may still be confusing ARC and HDMI 1.4 with 3D pass through. They are not related and can be implemented individually. BD players have nothing to do with ARC. They will never have it because they will never need it. They are only an output device.
It would be easier to understand ARC if you drop the BD player from the picture when trying to understand how to connect a receiver to a TV with ARC vs. a TV without ARC. They BD player has no bearing on this at all.
They are correct that you will only need one HDMI cable for video and audio from your BD player to your receiver if your receiver has HDMI ports that can support all the features of the BD player. So if you have a simple 2D BD player all you need is a receiver with HDMI 1.3 ports. If you have a 3D player then you will need a receiver with HDMI 1.4 and 3D pass through. It's only if you have a 3D BD player and an older receiver with HDMI 1.3 ports that you will need 2 separate cables. HDMI from the player connects to the 3D capable TV then a separate HDMI (if the player has one), digital coax/optical, or individual analog RCA cable to your receiver for audio assuming you want sound going to your stereo's speaker.
The only time you will need two cables connecting the same device to the receiver is in the case of the display to the receiver and you want to hear audio that is originating from the display itself played on external speakers connected to the receiver. Things like Netflix via the TV. The TV is running the Netflix application, but the user wants to listen to the audio on his/her stereo speakers and not the little TV speakers. In this case if the receiver and TV are not ARC capable then the he/she would need to run a seperate cable digital optical/coax or regular stereo RCAs in order to be able to listen to the audio from the the Netflix stream on the TV.
