Sounds good. Always nice to find a cheaper solution that gives you nearly the same results. I have a supply and return for my room attached to the whole house HVAC with a damper that I can use to shut off air supply should it get too hot or cold. I also plan to add a supply and return dead vent (one in the HVAC closet and one in the equipment room) to exchange air with the rest of the basement should I need it. I don't know if I will be able to have my fan be as accessible as yours though since mine would most likely be in the equipment closet which is basically in the theater (which means fan noise is bad).
post #181 of 401
4/23/12 at 7:47am
(well at least until I get my own house that is and do theater 2.0
And having never dealt with oil based paints before I completely forgot to pick up some paint thinner to clean it up.
