All the electronic gurus that hang around here and no one has any advice?
Originally Posted by aaustin
One more hurdle to get over with this plan; the transformer is too big to hide behind the crown. I stuck one from a laptop that is a similar size up there and it just won't fit. So I've got to find a way to house the transformer away from the soffit. Here's what I'm thinking:
There is a piece of romex that runs from the current four gang switch box to a box behind the crown. I think I will remove this piece from the switch box and take it out of the wall. I can get to it if I take a piece of drywall off of the backside of the staggered stud wall (not a big deal since that drywall is unfinished). This piece of romex will be long enough to reach into the hallway that the equipment closet is off of. I will house the transformer in the equipment closet and run a wire up above the drop ceiling to meet up with this piece of romex. Now here is where I need some help. I'll have to cut the end off of the transformer and splice in a longer piece which will then be spliced again to the romex in the hallway. Then I'll have to splice the end back onto the romex behind the crown on the soffit so that it can plug into the controller. I think the wire coming out of the transformer is coaxial cable? To splice this would I just strip a few inches off and bunch the outer conductor up to form one lead and then the center conductor would be the other lead? Then I could crimp the connections together?
I'd appreciate any advice on if this plan is even feasible.
Thank you!
Thank you!
