I bought 4 of the strip that you link here, I want to buy the 5 ir controller, what type of power supply do I need?Originally Posted by aaustin
Hi rschuler,
Yes, I did run the LED strips the full length of the crown.
Here is what you would need.
RGB LED strips (30/meter):
http://www.ebay.com/itm/5M-30Leds-M-RGB-5050-Waterproof-SMD-LED-Lights-Flexible-Strip-/160688397549?pt=US_Car_Lighting&hash=item2569c65ced
I had to buy two strips for a total of 10 meters. They can be cut every few inches.
A remote and controller:
This one has two outputs to allow you to connect two separate stands.
http://www.ebay.com/itm/44-Key-IR-Remote-Control-Controller-For-5050-RGB-LED-Light-Strip-two-outputs-/160774070507?pt=US_Lighting_Parts_and_Accessories&hash=item256ee1a0eb
There is also this one that has five outputs.
http://www.ebay.com/itm/44-Key-IR-Remote-Controller-For-RGB-5050-LED-Light-Strip-Five-outputs-/251024970634?pt=US_Lighting_Parts_and_Accessories&hash=item3a7241138a
A power supply:
http://www.ebay.com/itm/LCD-AC-Power-Supply-Adapter-DC-12-Volt-6-Amp-12V-6A-/280869637229?pt=Laptop_Adapters_Chargers&hash=item4165228c6d
Each 5 meter length requires 3 amps of current. Since I ended up using about 8 meters, I bought a 6 amp power supply like the one that I linked to.
Mr. Tim also just posted some very good information on voltage drop with LEDs over in his thread. It can be found here.
http://www.avsforum.com/t/1426519/mr-tims-15x27-theater/120#post_22687289
Let me know if you have any other questions and I'll try to answer them as best I can.
Hi rschuler,
A power supply:
