AVS › AVS Forum › Blu-ray & HD DVD › HD DVD Players › High Resolution Audio on HD-A1
post #1 of 10
Does anyone know if the Toshiba HD-A1 can play high resolution audio(24/192khz) in both cd form (physical disc) or via Flac or Wav files from a thumb drive or any other method of delivery? The manual claims 24/192 capable playback from all channels/inputs.
post #2 of 10
I don't believe the USB ports on any model HD-DVD player were ever activated or functional for anything.
post #3 of 10
Almost true ... I am able to charge my cell phone off the USB ports on my A2 and A30!
post #4 of 10
how about physical media high resolution discs?
post #5 of 10
Not DVD-Audio or SACDs. I've heard the Oppo Blu-Ray players can play them, and the latest Sony Blu-Ray players can play SACDs (though good luck finding many SACDs to listen to on them.)
post #6 of 10
I never thought of trying that . . too funny . .
post #7 of 10
Thanks for the responses, I might just have to buy a disc (around $50.00 retail!) and try it out.
post #8 of 10
Extremely well, indeed.
post #9 of 10
if you're talking SACD you could always get the 30th anniversary edition of dark side of the moon on a hybrid sacd for less than $15
as far as high resolution audio you could look into DAD and HDAD discs (DAD is another way of saying DVD-V with 24/96 stereo PCM... HDAD being a flipper disc with 24/192 DVD-A on the other side but your HD-A1 will not play the DVD-A side of such a disc)
the only way to get 24/192 on the HD-A1 is if there are any HD-DVD discs with 24/192 audio
post #10 of 10
Thanks, that's what i have just found out as well. thought I had a winner.
  Back to Forum: HD DVD Players
