****UNDER NO CIRCUMSTANCE SHOULD THESE SETTINGS BE USED WITH ANY OTHER SOURCE MATERIAL BEYOND THE PANEL PREP USB/SD CARD FILES****
Recommended 100 Hour Panel Prep Settings for North American Panasonic TC-PxxST30/GT30/VT30 models (ONLY to be used with Evangelo's USB/SD Card files!!!!!!!!)
*****Note: This procedure is designed to prepare your display for the reference settings listed below by aging all pixels equally with the same content. This procedure is NOT designed nor recommended to be used as Break-in, Image Retention and/or Burn-in prevention.*****
Photo Settings
Picture Mode: Custom
Contrast: 100
Brightness: 50
Color: 70
Tint: 0
Sharpness: 50
Color Temp: Cool2
Photo Enhancement: Off
C.A.T.S: Off
Video NR: Off
Pro Settings
***Leave all settings in this menu at their default***
HDMI Settings
Advance Picture
Block NR: Off
Mosquito NR: Off
Motion Smoother: Off
Slideshow Settings
Frame: Off
Photo Effect: Off
Transition Effect: Off
Photo Size: Normal
Burst Playback: Off
Display Interval: Slow
Repeat Playback: On
Photo Settings
Contrast: 100
Brightness: 50
Color: 70
Tint: 0
Sharpness: 50
Color Temp: Cool2
C.A.T.S: Off
Video NR: Off
Pro Settings
HDMI Settings
Advance Picture
Block NR: Off
Mosquito NR: Off
Slideshow Settings
Frame: Off
Photo Effect: Off
Photo Size: Normal
Burst Playback: Off
Repeat Playback: On
