AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Official 2011 Panasonic Settings/Issues Thread
Official 2011 Panasonic Settings/Issues Thread - Page 37
post #1081 of 1090
Originally Posted by pwrjnky View Post
just ordered one. picking up on Thursday. Didn't know if there were any of his settings floating around. My GT30 crapped out and warranty company cut me a check. Can you say U P G R A D E!!!!!! wOOHOOOOO:)
You are not going to find settings here, check out the VT50 settings thread
post #1082 of 1090
Just did. Thx
post #1083 of 1090
my panasonic tc-55st30 pictures a very unclear running downwards how can i fix it
this happens when i connect external devices like dvds,antenna or decoder but the usb output is good
post #1084 of 1090
I'm sorry for such a late response; you will most likely have to get your television serviced if the line is a constant on all inputs - it sounds like an HDMI issue if that is what your are using fork hookups. Call Panasonic and they will setup service, but you will have to pay out of pocket for the repair. Look into a warranty from Squaretrade for the future - cheap and reliable.
post #1085 of 1090
Sorry to bring this back. I notice that the new Break-in slides for the 2013 Plasma are different than the ones from 2011. I guess they are simplified?
Anyhow, is the brightest white slide in the original D-Nice Evangelo's USB/SD Card files linked in this thread a full screen 100 IRE white slide?
post #1086 of 1090
Can someone remind me how to tell if my 65vt 30 is the EEPROM updated or non EEPROM updated version? Thanks
post #1087 of 1090
August builds and beyond with seriel numbers begining with #1215 have the new eeprom installed from factory.
If you have an earlier build you need to go in the service menu to see which eeprom flash number you have.
Search this forum for a member named TFoltz, he goes into great detail on how to verify which number you have.
If you have an older version, you are gonna have to work something out with panasonic to get a tech to your house to get it flashed.
post #1088 of 1090
Thanks. I'm a nob build MJ series do looks like it has updated EEPROM like I suspected all of these years.
post #1089 of 1090
I have a nov*
post #1090 of 1090
I have a nov*
Your all set...
