AVS › AVS Forum › Audio › Speakers › Starter Home Theater
post #1 of 7
Hi Everyone,
I am just replacing my current Sony HTIB and was recommended this for my apt. I am looking for bookshelves only, not towers.
HSU VTF-1
4x Infinity P163:
1x Infinity PC251:
How does this compare with the Boston Acoustics? I have heard great things about the CS26's.
HSU VTF-1
4x Boston Acoustics CS26C Bookshelf (Cherry):
1x Boston Acoustics CS225 Center Channel:
Thanks for the help!
post #2 of 7
Klipsch also makes good bookshelf speakers. In general they will handle more power and may fit into a larger system later on. They are all good quality.
post #3 of 7
You should PM zieglj01 as I'm pretty sure he's familiar with both the Bostons and Infinities.
post #4 of 7
Thank you for your response.
Can you give me an idea of which Klipsch bookshelf speakers you are talking about. I can go and check it out.
post #5 of 7
Energy RC-10's or CB-20's.
The RC's matching center is the RC-LCR and the CB's matching center is the CC-10.
Im not telling you to go buy them but just giving you something else to look into. If you aren't planning on powering those Infinitys with a stand alone amplifier then I would scratch them off the list. They need more power in order to really shine. They aren't the most efficient speakers if you know what I mean.
post #6 of 7
You really might consider 5 identical speakers. They will give you the best uniform sound.
Have Fun!
post #7 of 7
HSU HB-1 mk2's for $129 each on sale. To save money, some use three HB-1's across the front for identical speakers.
They also have a 5.1 package with the speakers and a VTF-1 sub called the Enthusiast 1 package.
I'd do that over and above the Klipsch bookselves in your price range or those Infinity's. They throw large, impressive sound for the money.
  Back to Forum: Speakers
