Well , "Full Array" probably the best way to go , but I did see the 47" LM7600 and the picture quality was pretty good.
If there is no LM9600 47" , then I will have a close look at the LM8600.
I little something about full array , sometimes it can be too bright.
I tried Sony`s XBR929 last year I returned it , even with the ambient light adjustment turned on , it was still way to bright. I mean you had lower the brightness when you turned the lights off , or wear sunglasses !! LOL
I did not have a chance to see anything in 3D with the 929 , maybe that`s why it was so bright.
Unless the Panasonic 47" WT50 knocks my socks off , and the "active 3D " is better than "passive" , then I might take an even longer look at the 47LM8600
Later
Me
