Originally Posted by
john2910
Did you mod the hmz for better fit?
It came used with the cloth headband from Bravia 3D. It doesn't fit me perfectly, my profile must be weird, because there is no way I can use it without squishing my nose a bit, and the widest excursion of the eye lenses is just short of ideal for me.
Nontheless, I have become more impressed with it the more I have used it over the last several months because of the beautiful picture, great 3D effect, and it is really the best way to play games on Playstation 3. As I said, I think the OLED panels get better with time, a bit smoother and more luxurious in appearance.
I also really enjoy watching movies on it through the PS3. Standard DVD's that are of good quality look just great, and Blu Rays that much better.
I think I have gotten used to the fit more than anything, it goes right to the correct spot after using it for a while. The included headphones are decent for a theatrical experience, but being able to use my favorite headphones would be a plus. I have figured out a way to use high quality bud earphones through a home theater receiver, but it is awkward.
My cable provider has started allowing 3D movies on Starz and HBO, so I have been hooking up an HDMI cable directly to the cable box and the results on 3D movies through cable are impressive.
My greatest caveat aside from the fit was the obvious pixel structure, which seems to be getting better with time as well, or I am just getting used to it, it does seem smoother than when I got the headset. It was used, but only for a couple of weeks by another user.
