Hello guys. I've been shopping for those in Canada since the last 3 months. I found a second hand pair on ebay for 600$
without having been able to try them, i tought it would be nice to find some review on the net...
I've read all of the 103 pages of this thread and was disturbed by all the bad comments on this thread. It made me kind of unsure about the hmz-t1. I've been a vuzix user and myvu user but sony hmz-t1 sure blows my mind.
first thing i did was to set the display at 10 inches and try out wipeout hd... my got it's nice.
i tried call of duty, and first person shooter if more difficult. your eye have to move a good distance to look at the corner map and while you do that, you loose eye contact with the middle of game.
I've yet to try a 3D movie, i'll rent one tonight and go buy imax under the sea tomorrow.
I've created an account here to try to make clear some points :
- Pixel visible only on white writing like at the beginning of games... in game, no pixel visible at all and i have perfect sight.
- Comfort issue. Nothing on my side. i played with the straps and pads a big 10 minutes and i'm pretty confident it's perfectly adjusted now.
- Images are sharp and vivid. content is clear and i see no lag or ghosting at all.
- the people complaining about lot of lights reflecting on the lenses, it wasn't my case. i played at noon with my blinds open and i couldn't see any kind of flare on the optics without even using the lights blocker. If you were to play with a light source coming from behind you, i guess yes, it could show flare / glare.
the only downside for me, it's difficult to find the sweetspot. it even seem impossible right now. i think i will have to do the mod for the lens adjustment to work independently. i've tried lots of different options, but one eye will always be with blurry edges. to have it direct on my face without any pads didn't help.
playing with the lens adjustment slider, or my right eye would have blurry edges, or my left eye. i can't get both eye to show perfectly clear picture.
I definately give the hmz-t1 a 8.5 out of 10.
Anyway, i was so depressed after reading the reviews / comments on this thread, now that i'm a owner myself, don't worry i'm confident you will be impressed with them.
CHEERS !
CHEERS !
