Good afternoon. Read the forum for a long time. I want to share remake Sony hmz-t1. More precisely addition to points, or how many points do not hurt, but one of the pads on the forehead).) Maud removed and worn like changing myagkooy pads on his forehead and held and tightened the rear straps. Points purchased several days ago. Once the glasses came immediately attached a strap from the top, the less steel to sit on his head, but decided not to go into this mode, because I love that everything was perfect))). Made measurements of the head, the frame cut out 8 mm PVC, in the middle of the design made a significant narrowing of that framework could be spring, rounded technical phenomenon in the form of his head, papered with dense black foam (it can be found in packages of video cards, etc.) . Pasted a headlamp trim (only plastic) into the base of the frame, the back side, for balance stuck car balance weight 180 g. (That would lead not stained by treating them with liquid acrylic plastic). Now the "Helmet" perfect fit on the head, does not outweigh or falls on the nose, and increased weight (and that's a plus about 300 gr.) Because of the balance is not there when in use, virtually no blurring at the edges and is barely visible on the desktop the upper corners of the desktop windows, (not even pay attention.) You can move your head in any direction, the image is "almost" not break very rarely corrected.
For total immersion, ordered 3 axle 9 degrees of freedom, Insertable tracker gyro sensor (gyroscope, accelerometer, magnetometer and temperature sensor-All in one). It can programmatically emulate either a mouse or a joystick in any games or programms. the most important thing that he can keep the center of the screen, and when the rotating head in the game, and then return to head back to the center, the image does not go astray. Same as TrackIR5, only a hundred times cooler. The same plan used tracker on Oculus Rift. In place of it, until the sensor in a way, I use Logitech Air Mouse (sometimes feel dizzy and nauseated)
Here is the sensor.
http://www.youtube.com/watch?feature=player_embedded&v=eUmHRW0q3aQ
I am not an avid gamer, but a little hooked on "HAWKEN" online game and that would please))) "of a loved one," has made a virtual chair, vibrate so that will not find, but with glasses)) - "almost complete" immersion in any game or film. For added versatility to the chair Version))), and sometimes drive i want.
Computer chair was taken "Pilot-2", vibration cape GameTrix JetSeat, convertible table for notebooks CBR, steering wheel Logitech MoMo, manipulators Razer Hydra (on chair under them made adapters for use as joysticks in any game), Keyboard and Mouse, tablet)).
Also use Virtual Audio Cable. It redirects the sound to several sources in Win7, such as goggles and vibrating chair (vibration cape GameTrix JetSeat use sound low frequency, or USB)
Sorry for my English (I use Google translater)
Edited by dashkitusa - 2/23/13 at 3:36am
