AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Official Power Sound Audio Thread
Official Power Sound Audio Thread - Page 16
post #451 of 10049
Or maybe Sonic Barrier. This stuff comes with "PSA", which in this case doesn't mean PowerSound Audio but Pressure Sensitive Adhesive. Either way, it seemed like a nice tie-in... biggrin.gif
post #452 of 10049
Originally Posted by Slingblayde View Post
Not worried about them vibrating off the top of each other? I mean you would obviously see it, its not like it would fall on the floor, but I wonder if it will end up where you have to realign them after every movie. Maybe place some sort of cloth or something between to act like a gasket to keep the surfaces from sliding around?
More than likely, you won't see the movement happening because it will be dark in the room as you're watching your latest action movie thriller and then "BAM!", over goes the upper subwoofer from vibration caused movement as in;"WTF!". Not good. Ruins a good movie when that happens. tongue.gif
As a suggestion for preventing movement, use small round rubber pads which are a bit larger than the subwoofer leg ends. The smooth rubber will grip the top surface of the lower sub and the legs of the upper sub will indent the rubber pad which will have the affect of gluing the two subs to each other with no damage to the lower subs top surface.
If one uses natural fiber material, unless glued or taped in place, the material won't stick to the surface and "WILL" move about. Not good.
Hope the above helps.
Edited by BeeMan458 - 11/18/12 at 4:03am
post #453 of 10049
Originally Posted by walke108 View Post
Thanks for sound tip in the options menu. I had not seen that yet! I can't imagine it being any louder than it already is when the bombs are being dropped. I am pretty jealous of the duals. I have no space and my wife would kill me. Would love to see a picture of your stacked duals, and the 4 TV's! That is going to be one hell of a fun time for you guys.
it was one hell off a time thats for sure. my phone wont let copy and paste a picture on here any suggestions? and it wont let me send it to my email either so new phone i guess is nxt i know alot of ppl were putting pics on face book but i dont have that i will get sum up here some how for u guys.
Originally Posted by vardo View Post
Nicker1987, just curious. In your equipment list you have a Panasonic 65st50 TV listed.(Great TV BTW). Wondering what (if you don't mind)
what your other 3 TV's are. If they are Panasonic 65st50 that would be beyond awesome!
vardo
nope i wish i had three more of them my other is a 42 panasonic plasma cant rememeber the model the most exspensive in 2010 is all i know lol. the other 2 is my room mates 50'' sumthin cheap and nother 42'' cheap vizio. i have another 65'' at my parents i need tp bring here i sold it to them and they havent used it once and that was 8 months ago so im gettin that back its a 65st30 the model before mine.
ahblaza every time bombs would go off my friends would turn around and say nick thats awesome haha so that made my night.
slingblayde they havent moved an inch because they are heavy and the surface is a sand paper ish material and they hold each other together prty good and last night had a tv on top so that helps but any other times never had a problem at all moving
slingblayde they havent moved an inch stacked i think
post #454 of 10049
Originally Posted by BeeMan458 View Post
Hear you my man:D
post #455 of 10049
Originally Posted by eljaycanuck View Post
Good point. Something like this (pro-grip shelf liner) should work well. (I used it to keep the SHO-10s I was demoing from moving around on my subs.)
eljay, I will be going for your placement setup also, Tom actually suggested placing them in the front L&R corners, as he knows my room and how well one is performing in the right front corner, hopefully I will have the second soon. Nice setup brother:)
Cheers Jeff
post #456 of 10049
I have placed the subs eljay style, on either side of the screen. I ran YPAO on my older Yamaha HTR 6080, bumped up the subs a couple DB, and fired up Saving Private Ryan, I was blown away. I watched Disney-Pixar's Brave tonight also, great movie, excellent 3D and very good sound.
Needless to say I am EXTREMELY satisfied with these subs. Now hopefully the Onkyo 818 goes on sale for Black Friday, I think thats what I'm going to use to run my HT. The HTR 6080 is nice, sounds good, but it just doesnt have enough HDMI's on it (2 in,1 out) I like the 8 HDMI's on the Onkyo, and I like the SiriusXM feature, but the rest of the goodies like Pandora, Spotify etc, I probably wont be using.
Kudos to Power Sound Audio for making subs that kick buttocks!
post #457 of 10049
Audioholics just released their review on the XV15: http://www.audioholics.com/reviews/speakers/subwoofers/xv-15-subwoofer
post #458 of 10049
That is a superb review especially in light of what that sub costs. Well done. smile.gif
post #459 of 10049
Good review of things!
post #460 of 10049
all the people holding out for the Ricci review now no longer have a reason to delay any further smile.gif
post #461 of 10049
Looks like a very solid unit for the price. Nice job Tom and co.
It also looks like the Hsu VTF-15H is still a very well priced competitor.
post #462 of 10049
Hard to say. I'd ultimately like to see a retest of the VTF-15H given the controversy/potential problems with Paul's tests (fat chance).
post #463 of 10049
I'm just going by the 20hz max output seen in several tests, which were several dB higher with the VTF. That obviously doesn't tell the whole story, nor does it diminish an excellent product being put out by PSA. You'd be hard pressed to find better value at $799 than the XV-15. They both seem like subs where not much profit is being made per unit, as the build cost is likely very high.
post #464 of 10049
Not sure if you're aware of what happened with the VTF15's numbers.
http://www.audioholics.com/reviews/speakers/subwoofers/hsu-vtf-15h-supplemental/hsu-vtf-15h-cea-test-results
Paul originally measured 20Hz output at 1m, peak as 109.9dB; subtracting 6dB to go from 1m to 2m and another 3dB for peak to RMS, and you get 100.9dB @ 20Hz. He retested it later and was able to get an additional 1.2 to 1.7dB depending on various factors. Hsu fans were apparently not pleased with this result (although the other manufacturers of the other products Paul measured around that time, Rythmik, SVS, and Funk didn't have any complaints), so now the story is that Paul must have made an error...twice, and apparently only with the Hsu since Josh's numbers line up with Paul's numbers quite well on the FV15HP. Suffice it to say, a bad taste was left in everyone's mouth, so I doubt we'll ever see the true story, and 3dB was added to Paul's numbers across the board to try and put the matter to bed.
post #465 of 10049
It would be nice to see Josh's data (if he ever reviews it)just for consistency. Based on the latest(?) charting I saw at AH it looks like the overall output of both units is very similar across the entire (measured) band width...20-63hz (within a dB or so) Both are very good products imo giving the consumer a couple of excellent choices in the $799(XV15)- $1018(Hsu) price range.
Tom V.
Power Sound Audio
post #466 of 10049
Ah, that's right. So, going with the retested numbers, the two subs are looking very similar in output.
post #467 of 10049
Tom V.
Power Sound Audio
I'd say so. Your products are making my upgrade path quite a bit more interesting. Really solid effort.
post #468 of 10049
Thanks LeninGhola,
Being competitive in this industry can be difficult when one of the primary "missions" is to source everything possible from other USA based vendors while doing all of the assembly and QC in Ohio. We know we are atypical in that regard but that's okay as we are are hoping to start a trend..smile.gif
No plans right now for Josh Ricci to get the XV30. Basically you can just look at the XV15 review and add about 3.5dB across the board. The two models share all important design considerations. In fact, I doubt anyone would be able to discern one from the other up to the linear output limits of the XV15.
Tom V.
Power Sound Audio
post #469 of 10049
Josh's review confirms what I already knew about my dual XV15 and validates the risk I took a few months ago. It's a great product at the price point. I don't have any EQ yet (xmas smile.gif ) but I'm fortunate to get solid +/- 5 response from 80 to 16 hz at my MLP. The design with room gain expected to bring up the low end will vary greatly from room to room, but it works perfectly in my room.
One more thing, Tom. The fact that your products are sourced and built in the USA minus the amp was a big selling point to me. Well done, and I hope this factor sways more people to chose PSA.
post #470 of 10049
post #471 of 10049
post #472 of 10049
Originally Posted by Reefdvr27 View Post
And 65 pounds!
I still can't get over how many XV30s we have shipped lately. On the bright side our cabinet vendor mentioned he may need to add another "shift" (I'd guess 2-4 employees) to his spraying process to keep up with our increasing demand.
Tom V.
Power Sound Audio
post #473 of 10049
This may have been asked already, but are there any plans to make front firing subs?
post #474 of 10049
Great to read this review after having placed my order last week...makes the wait to get my delivery that much harder. Was originally scheduled to be delivered 11/20 but FedEx just changed that to 11/21 (yet still says on time delivery). Oh well, I've waited this long, one more day isn't going to kill me.
post #475 of 10049
Got my dual XV-15's hooked up yesterday. Want to thank Tom V, these are absolutely awesome. Loved my HSU VTF-3/3......but these, well
never mind. Could not be happier with Power Sound Audio.
post #476 of 10049
Got my XV15 today...WOW! So much better than what I have been used to. Ran Audyssey XT and then fired up Cloverfield bridge collapse scene. My girlfriend came downstairs in a panic to tell me that the dishes in the kitchen cabinets were rattling like crazy. The system volume was only at -30db...I love this thing! I can't imagine running at reference sound levels.
The first thing that I noticed, besides the huge gain in output, is how clear and clean the bass sounded. My old sub, a Polk PSW111, always sounded really muddy to me and really struggled.
Of course, now I'm feeling like the other speakers in my setup need to be upgraded too to match the quality of the PSA sub...it never ends does it? tongue.gif
Edited by hoss1000 - 11/21/12 at 7:32pm
post #477 of 10049
"it never ends does it" lol i dont think it does, iv only had my speakers few months and i want to upgrade again and 2 xv15s 3 weeks and already want 2 more haha yup never will end
post #478 of 10049
Gratefully if it ever ends. And yes, it becomes depressing if it does end as then there's no tomorrow and you have to start looking at Bass Boats. eek.gif
post #479 of 10049
Bee,
It (I think) upgrading never ends. Over 60, and just upgraded to two XV-15's. eek.gif
post #480 of 10049
Bee,
Congrats on your new upgrade. From reports, once dialed in, you're going be very happy. Today I decided to commit to a DSPeaker Anti-Mode 8033 C. I'll put the order in on Friday or Monday, when ever they start picking the phone up again.
Told my wife I needed a new toy today and this seemed like a good expenditure of toy monies.
