AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Official Power Sound Audio Thread
Official Power Sound Audio Thread - Page 251
post #7501 of 10009
Here is a thread Shady J started and I am sharing the link
http://www.avsforum.com/t/1502245/finally-we-have-a-simple-way-to-rate-and-compare-subwoofers
Edited by Reefdvr27 - 11/28/13 at 9:16am
post #7502 of 10009
Originally Posted by Reefdvr27 View Post
Not you.
Somebody's just trying to stir up dirt against PSA and make it look like they're just being a public service.
post #7503 of 10009
Not you.
post #7504 of 10009
Here we go!
Does he have an inferiority complex, or really that bored with his life? He's just looking for someone to take the bait.
post #7505 of 10009
Originally Posted by eljaycanuck View Post
What!? Reef is not shady? I'll be da....
post #7506 of 10009
I could be mistaken - that's why I didn't say he definitely knows he's not. wink.gif
post #7507 of 10009
I just want to make sure, via the posted word, I don't screw up my innuendos. tongue.gif
post #7508 of 10009
post #7509 of 10009
post #7510 of 10009
I don't get it
post #7511 of 10009
Originally Posted by D Bone View Post
I don't get it
Don’t feel bad, nobody gets my/our humor. smile.gif We’re just playing. Your're not the long lost Chad are you? biggrin.gif
post #7512 of 10009
I don't get it either? What are you saying not me for? I just shared a link.
post #7513 of 10009
I was playing with eljays post is all, not you Reef. smile.gif If indeed you're asking me??
post #7514 of 10009
Are you sure eljay wants you playing with his post? Better ask him first!
post #7515 of 10009
As long as he doesn't put his hands anywhere indecent, I'm OK with it. biggrin.gif
post #7516 of 10009
post #7517 of 10009
post #7518 of 10009
Zing!!
post #7519 of 10009
post #7520 of 10009
Okay PSA fans, I have an XS15 in a 1650 sq. ft.. room. I have a Marantz 8801 pre/pro with a Cinenova Grande 5 channel amp. Von Schwiekert speakers in a 5.1 set-up. I will add height speakers in the future. Running Xt32 and still don't feel the kick in the chest feeling. What do
I gain adding another XS15? I have 2 openings one in to a hall way, another in to a family room. I sold a PB Ultra 12, one of the first one sold when it was
post #7521 of 10009
Do you mean cubic feet? 1650sq ft would be one huge ass room!
post #7522 of 10009
Assuming you meant 1650cf, the XS15 should be plenty for that size room but adding a second XS15 would certainly help. I would also try the sub in different locations if possible. I ended up with mid sidewall for my dual XV15s and it sounds very good but every room is different. What do you have your sub gain set at?
post #7523 of 10009
I would definitely check placement and sub gain level as was already mentioned. Have you done the sub crawl to identify a good location? What are the dimensions of your room in cubic feet? (Length x width x height)?
post #7524 of 10009
My room size is 15' x 12' x 8' 9" and no I have not done the sub crawl but need to do it. When I ran XT32 and set the sub's gain. it is about 12:00. The PB12 Ultra just seemed to have more punch. Getting ready to order the UMIK-1 this should give me some info on what I need to do.
post #7525 of 10009
The sub should easily be able to handle that room size. What is XT32 setting your sub channel at? The owner's manual of the XS-15 states to set the sub around 2:00, this may give you the added bump you are missing. It is standard to set the sub's gain at 2:00.
I would adjust the gain, then do a sub walk and see what position sounds best and go from there. That Umik will obviously help out a ton as well!
post #7526 of 10009
When I run XT32 it has me set the db. level to 75 and that was 12:00 on the gain dial. It would not let me continue until I did this. should I get out my SPL meter and set it to 75?
post #7527 of 10009
Yes that is correct. My room is the same size and xt 32 puts my gain right at 12:00. I have dual xs 30's and they make my floor ripple. Damn I love these subs!
post #7528 of 10009
Have any of you guys heard a Rythmik up against a XS30? With all the talk about how great Rythmik SQ is does the PSA match it? Kinda like the look of the XS30 the best out of the subs I'm looking at and think it'll look good as a side table or behind the coach. Think I'm down to custom made Rythmik sub from Salk Sounds, Funk Audio sub or the XS30, like how the PSA sub will be the easiest on my wallet and likely get it the soonest.
post #7529 of 10009
There is a review of the xs30,Hsu uls15 & Svs sb13u....although not a Rythmik the 13u should be very close in terms of SQ if you consider the driver used. AAMOF...once my XS30 arrives I'll have a chance to compare it with a loner Svs sb13u which was offered to me from another local member. The aforementioned review is excellent IMO very descriptive and full of detail...which likely won't be matched by mine...but having those 2 subs in home should be a lot of fun...if the XS30 comes close in terms of SQ...I'll be a very happy new owner because I know it will have more over all output and closely match my Sierra Towers gives it a big plus...in my book.
Btw here is that review... http://www.avsforum.com/products/xs30/reviews/4360
post #7530 of 10009
Just watched the Conjuring with my xv15. lol smile.gif I'm not sure how low the bass really goes, but I think the areas where it creeps up to you is pretty cool. Bought the movie on-sale for $8 last Friday. smile.gif
