AVS › AVS Forum › HDTV › Local HDTV Info and Reception › San Antonio, TX - HDTV
San Antonio, TX - HDTV - Page 143
post #4261 of 4332
Originally Posted by jag2006 View Post
I wont be able to move the TV It's already mounted and would be a pain to undo...
Okay, can the set in your son's room be moved and tried on the line to the TV near the cable modem? Just move the RF connection to the other TV and see what happens. (This step rules out the tuner and maybe modem interference in your main TV.) Also, try the RF line from the splitter; take the line off the splitter and put it directly into the TV and try. (Rules out the splitter.)
If all this fails you may need to request a visit from the folks at Time Warner to check your signal quality at that position. Boosting the signal with additional amplifiers is not always the best idea. The signal may already be too strong for your tuner's front end. You also could also be suffering from interference due to the proximity of your cable modem, or even a faulty cable modem. A well-equipped installer should be able to determine the problem.
post #4262 of 4332
His BKT Corp. did the maintenance on many of the broadcast towers in this area
http://www.legacy.com/obituaries/san...4256&fhid=8901
A friend of 40+ years.
post #4263 of 4332
Thanks again I will try your suggestions.
post #4264 of 4332
Now there's a conflict with Direct TV and Kens. Kens wants more money. D* says they are negotiating. So if Kens goes off D*, am I expected to put up a very high antenna and then run wires that would run all over inside the house to connect 3 tv's?
All the sets in the house are next to inside walls where cables were fished when the home was built. In addition, there are too many obstructions here in Leon Valley. Two story houses and too many trees would block the line of site to Elmendorf. Not to mention, my main HD tv does not have an HD tuner. It's an older set.
So, does that mean I would qualify for a signal from New York or L.A.?
post #4265 of 4332
Originally Posted by n3vino View Post
run wires that would run all over inside the house to connect 3 tv's? All the sets in the house are next to inside walls where cables were fished when the home was built.my main HD tv does not have an HD tuner. It's an older set.
You don't have to "run" cables all over your house in fact you can use the ones already there to distribute the signal for you.
For the older TV sets you'll have to get an inexpensive converter box, try radio shack or even amazon.
I don't know what you mean by getting signals from NY or LA..
post #4266 of 4332
The cables already there are configred with swm and hooked up to a dish. I wouldn't know how to hook up an antenna to them and I don't know if it can be done without going through any additional expenses. A converter box would not help since I would need a very tall antenna to clear the trees and the two story house that obstruct the southeast path to Elmendorf.
In the Direct TV questions and answers about that, they say that we would not be able to receive programming from any other city due to FCC protecting local broadcasters, unless we are not able to receive local programming over the air, or if I get a waiver from them.
post #4267 of 4332
If you want to put up an outside antenna, but not run additional cables inside, there are special splitters available that let you "share" a single coaxial cable for satellite and an OTA antenna. Radio Shack probably sells them. You need one outside to combine the signals, and you need another one inside behind the TV, to split them out again. The splitters look like conventional splitters, with two connections on one side, and one on the other, but they need to be marked "ANT" and "SAT".
Even though you are quite some distance from the station's transmitter, it's still possible an indoor antenna would work. KENS' signal is UHF, which is probably easier to pull in than VHF. Maybe you could try an inexpensive indoor UHF antenna first, to see if it would work? If it does, you could just buy a dedicated indoor antenna for each TV set.
It isn't just KENS, but a bunch of Belo-owned stations all over the country that are facing a Nov. 1 deadline with DirecTV. Chances are, an agreement will be reached by then, or a temporary extension granted.
post #4268 of 4332
Again, there is a two story house directly on my southeast side of my house. There are a lot of tall tree in their back yard as well. My street runs from southeast to northwest. I do not believe I have a clear path to Kens transmitters. I am in Leon Valley.
But still, I don't think I want to go to all that trouble. At least not yet. I wonder how well Belo would do if they lost all those viewers. After all, advertising dollars depend on viewership.
post #4269 of 4332
I do not believe I have a clear path to Kens transmitters,But still, I don't think I want to go to all that trouble. At least not yet.
trial and error, right?
Get a cheap rabbit ear antenna from radio shack and if it doesn't work then you can go with an outdoor one and see as well.
post #4270 of 4332
Got the exact co-odinates from my house to the Kens and other local transmitters. I have two big trees in my backyard. There is a two story house caddy corner to my back yard which probably would not be a problem because ony a corner of that house is in the way looking at a straight line to all the transmitters in Elmendorph at 26.9 degrees from my house.
Questions. Would the tall trees be a problem? They have a lot of leaves. Also, what would be a good not to expensive stand alone over the air HD receiver for my older CRT HD TV? And could I use the same cables with a D* swm system? My roof would not be in the way so how high would the antenna have to be from the ground?
I'm starting to want to have the option of over the air HD for all our locals.
post #4271 of 4332
I don't think tall trees pose much of a problem, unless you are trying to use too small of antenna in relation to your distance from the transmitter. Some people report good results from mounting their TV antenna inside their attic, provided there is enough room up there, and they don't have a metal roof.
I'm not sure about the standalone HD TV tuner. I know they are available, but probably not a lot of demand for them. The tuners that were sold under the government's coupon program would receive the HD channels, but would only output in SD resolution.
Some of the newer DirecTV receivers allow free local OTA channel reception from an antenna, which will probably get you some additional channels (subchannels), on top of what is included for local channels as part of your satellite subscription. An additional module may have to be purchased for some of those receivers to allow you to do that, if it is not a built-in feature.
I'm not really familiar with how the SWM system works. The splitters I described in a previous post requires one outside for you to connect your satellite dish and TV antenna to, and one inside behind the TV to split it back out, sharing a single cable that is now just carrying your satellite signal to your TV, instead of running an additional cable through the wall.
I have a rooftop antenna on a single-story house with a low-pitch roof. No 2-story houses immediately around me, but the antenna is pointing directly at a cedar elm tree in my yard, and at a 2-story house about 300' away.
post #4272 of 4332
Thanks for your response AV.
post #4273 of 4332
After nearly 2.5 years KLRN-9 gets to up (double) its ERP http://www.klrn.org/dtv/
Being c. 17 mi away OTA (with an outdoor antenna) from them was never a problem for me. I guess that the smaller-market KCEN doesn't need as much coverage-area protection as before (the reason that KLRN had been stuck with such a low ERP all this time). They must have had things at-the-ready to implement it so quickly after it was granted.
post #4274 of 4332
Thats good to hear, Dish just added the HD feed for local PBS # 9 & KCWX #2. Still need the CW in HD # 35, but glad to have the other two as over air signal is very weak and difficult to pick up. I was getting ready to change all my PBS recordings to Dish HD SAT feed which is a little softer, so now, I will leave it as is. No more break ups of ACL will be nice.
post #4275 of 4332
TXMAN, You still around,
Any update on progress of audio fixes at WOAI?
I have sound out of 5.1 speakers, but things do not sound quite right.
If I Plix out to 7.1, I get no sound out of the side surrounds? Anyone else notice this.
Superbowl is coming up on NBC
post #4276 of 4332
KCEN has been a thorn in my side up here in Dallas. With the slightest bit of tropo or fog, they routinely interfere with KFWD, a scant 92 miles north, operating directionally with 13 kW. It seems to happen whenever I want to watch the replay of Dale Hansen's sports (from quasi-sister WFAA).
My rant about KCEN's allocation is getting old (after nearly three years) but I still don't see how the FCC was able to wedge it in, Longley-Rice studies notwithstanding. And I realize that atmospheric conditions don't weigh into the consideration. But still...
post #4277 of 4332
In the NTSC days KLRN's nearest full-power co-channels were Abilene, Lufkin, Reynosa. Due to my antenna headings for them from here they actually got a lot more destructive CCI from the zero-beat WAFB in Baton Rouge (c. 450 mi)! Zone III spacing for tropo somehow got ignored when DTV came along. http://www.qsl.net/wa5iyx/hivusntsc.htm
post #4278 of 4332
The application for KCWX's "translator" on Ch 8, 600 w, is apparently going to be on the KLRN tower. Being at 17 mi for me, in the same direction as Corpus's KIII, it may suffer from CCI when tropo is up. Co-siting with KLRN avoids the xltor from being stronger than the PBS outlet on that adjacent channel anywhere in the coverage area.
post #4279 of 4332
Awaiting the explanation for the prolonged Thursday evening session of non-decode on KSAT's OTA signal. By 11 pm 12.1 had back just an ident graphic, but 12.2 programming was back to normal. I guess "technical difficulties" graphics were thought to be no longer needed these days
OK, the Friday noon news on KSAT explained that it was due to an hour-long power outage. http://www.ksat.com/news/Power-hit-t...0/-/index.html
I knew that it had to be studio-related as the transmitter was still on.
post #4280 of 4332
Anyone having bad audio on KENS NFL playoff game broadcasts this weekend? All sound is coming from center channel and LFE only, nothing from L-R, or surrounds.It sounds terrible. Last weekend's Steelers-Broncos game was perfect.
Is this KENS or CBS?
post #4281 of 4332
I am able to pick up Fox, NBC and CBS as well as Univision and Telemundo on clear HD, but I can not pick up channel 12.1 for ABC...any suggestions
post #4282 of 4332
Need a VHF antenna.
post #4283 of 4332
Thanks...I went to antennaweb.org and you were 100% correct...thanks
post #4284 of 4332
The NOAA weather radio is off the air in San Antonio until Friday. (http://www.srh.noaa.gov/ewx/) I have muted the input to the KENS 5.3 service to spare your ears the lovely white noise that lives under where the audio used to be.
post #4285 of 4332
Checked 162.55 MHz on my FT-847 (with 2m 11-el 16' AGL beamed n.e.) and found WNG692 from Carrizo Springs on there (including the announcement that SA's WXK67 is off!) There are so many NWS stations on the other NOAA freqs in this area that I've lost track of them. When tropo is up it becomes bedlam - a far cry from the early 1970s when Corpus, Galveston, Brownsville, et al could be heard with a whip (before WXK67 debuted c. 1977).
http://www.nws.noaa.gov/nwr/stations.php?State=TX
post #4286 of 4332
The NOAA radio transmitter was probably restored to service late Friday afternoon, be we didn't get back to our encoder until Saturday. As of 1645 CST Saturday, NOAA radio audio is back on KENS 5.3.
Next time we find out about a NOAA outage I will see about tuning to one of the neighboring transmitters. At the very least we could have enjoyed current conditions for our general area - if not a bedlam of co-channel interference from so many on the same frequency!
post #4287 of 4332
If WXK67 is still sited at the Methodist Hospital that's c. 3-mi LOS from me so with their 1kw it doesn't take a lot of antenna to get them here. Even those other NWS channels nearby can sometimes get strong enough that just a whip will pick up a few of them.
post #4288 of 4332
Anyone else lost picture on timewarner chi 111, for the 49er game?
post #4289 of 4332
Apparently quite a few viewers in Northwest San Antonio were affected by a TW outage this evening, displaying a freeze frame of the last action seen on some channels (FOX) and a black screen on others. Analog cable was briefly affected also, resulting in old-fashioned snow on multiple SD analog tier channels interpersed with a few spurts of full-field color bars. When called TW acknowledged an awareness of the problem and that they were working on it. The analog lower tier was quick to return, the HD tier took a little longer. I personally found Road Runner internet service spotty at times between 7 and 8pm but that was minor compared to the TV outage.
post #4290 of 4332
Thanks for the reply seems to be working now
