Originally Posted by
jriver
DLNA is actually pretty cool when it works, but the standard and its implementation are a little rough sometimes.
I would agree. DLNA is what it is. The issue is that the vast majority of products that implement it, only implement the bare minimum such as to allow them to stick a DLNA sticker on their box, resulting in endless hassles when a person actually wants to use it for much more.
As far as converting the FLAC to uncompressed PCM before sending it to the player, that may be fine. Maybe. The issue I have with converting FLAC to PCM at the PC is not in quality degradation, which shouldn’t happen, but in requiring CPU time to do the conversion. I know it should be minor for audio (and in reality perhaps it would be completely unnoticed) but it still requires the PC to do the conversion, which offers the chance for it to get borked up if the PC is also doing other things. As it stands today, I have yet to suffer any “server side” bottlenecks when the audio/video is strictly being read off the HDD and shuttled out the door to the NIC.
Perhaps things have changed and this is no longer a problem, but at the same time, it is quite frequent where others in the house are relying on the “server” pc to serve media while I am using it to do rather intensive activities like Photoshop and Vegas Pro NLE editing.
That said, I wouldn’t switch over to a system that expected to transcode video codecs to *another* video codec before sending it out to the player. Not a chance. I’ve gotten too spoiled by the sage extenders.
jriver
Define "proper media sharing".
The media is stored at a server, as it is. Either as it was packaged in the original video/audio codec in the native ATSC/QAM stream, as it is in the original MPEG/AVC/VC1 codecs used at the time the person ripped the DVD/BR discs, as it is in the original codec straight from the home camcorder/NLE editor or even as it is at the time they downloaded it from the net.
The media then gets sent via the LAN to the player, as it is (see above) for the player to decode/playback natively at the display.
Repackaging into alternative containers on the fly (mkv<->m2ts, TS<->PS, etc.) is ok, …but frowned upon.
-Suntan
