Originally Posted by
sdurani
Thanx, as long as we keep the benefits in perspective and not treat it like some magic bullet.
who here is insinuating that a 'tool' which details a user how specular energy is impeding the listening position is a 'magic bullet'?
the tool in context of this thread is with regards to the 'defined goal' of attenuating an early specular reflection - and verification once 'treatment' (be it an absorber or reflector or diffuser) has been procured and placed to confirm that the 'treatment' resolved the identified and measured 'problem' sufficient to the user's criteria.
it also identifies other sources of incident energy that may otherwise not be so obvious as that of 'large boundaries' - such as edge diffraction or specular reflections from other objects or surfaces within the room. is the ETC not sufficient for such identification?
why is it we never see such vicious confrontation on this forum when another user recommends "the mirror-trick"? yet recommending the actual tool for the job to verify that the absorber is placed properly and is sufficiently attenuating the specular reflection across the entire listening position (be it single seat or multiple rows) brings about all sorts of confrontation...
sdurani
A measurement tool that displays energy over time is more valuable in a situation where you're targeting all energy/reflections within a particular time range, like a studio, than reflections based on direction and spectrum, like a living room.
who are you to say what information regarding the room's specular response is 'valuable' or not? who are you to say or insinuate what the acoustic response should be of a user's room? do inherent issues within small acoustical spaces change based on the function of the room?
whether one allows early reflections to impede the listening position or not is not the discussion. the acoustic response a user is looking to achieve in their room is not the discussion. whether a user is looking for an accurate, critical listening space or a pleasing listening space based on 'their' subjective tastes, is not the discussion. instead, it's about using a specific tool for a specific job. if you want to discuss differing acoustic responses, then by all means start a new thread.
sdurani
You don't see designers of home theatres and music listening rooms that post on AVS talk about the Haas kicker the way posters on GS do. [BTW, what happened to all that talk about the Haas kicker? Seems to have quietly faded away.]
if a particular user has made the decision to attenuate early reflections (and implemented 'treatments' accordingly), then by nature you are creating an 'effectively anechoic' response at the listening position for a specific amount of time (inter signal delay) - such that any energy arriving within this time gap is below the human detection threshold and thus, not processed. unless the room is completely damped, then eventually, specular energy will be reintroduced to the listening position. this is essentially the 'termination' of the 'effectively anechoic' time-period. with the use of diffusers, the 'haas kicker' can indeed be of a diffused termination. the problem is, the diffused returns will (by nature) by lower in gain than a specular reflection termination - as such, if one wants to adhere to the psycho-acoustics for the termination (haas trigger) to remove the localization cues from the later arriving specular energy in the room and force the brain to 'lock-on' to the direct signal, then the termination (trigger) needs to be of sufficient gain. this is why you may find reflectors being used in place of absorbers at early reflection points - to maintain and preserve as much of the finite, specular energy in the room as possible such that it can be managed appropriately based on the user's desired acoustic response.
sdurani
But you're doing something similar by suggesting generalized ETC measurements without any caveats. Problem is, the strength of a reflection (how tall the spike is in an ETC measurement) is affected by the frequency content of the reflection.
precisely as stated as early as post#10. the lower energy has longer wavelengths containing inherently more energy. it is also very likely that the lower specular region will be more 'off-axis' than the HF (highly directional) content (speaker dependent) ... as such, the focus with regards to attenuating (absorbing) early specular reflections with porous (velocity-based) insulation is that the absorber needs to be effective down to the lower specular region. hence, why 'thin' absorbers are not recommended, as they simply 'filter', 'EQ', 'color' the reflection by attenuating the HF band and allowing the low-mid specular energy to persist - and why one should measure to determine the effectiveness of their absorber at attenuating the 'entire' specular reflection (and this is why attenuation is with respect to overall gain - NOT frequency).
sdurani
At least the Mellor/Hedback paper mentioned earlier talks about using bandpass filtered ETCs rather than a generalized one.
Only if your objective is to supress all reflections within a certain time period, like when designing a studio. That's where a measurement that gives you energy over time, without caring about the spectrum of that energy, is most useful.
first of all, i am not sure why you feel particular acoustic responses that look to address fundamental issues of being constrained to small acoustical spaces (where time domain takes precendence) - is somehow limited to 'studios'.
tell me, what is the 'goal' of a 'studio'?
why do you feel that a particular user may not wish to achieve or implement an acoustic response of a 'studio'? if you want to discuss differing acoustic responses, then by all means do so in a new thread. but please refrain from introducing such debate and distractions from this discussion which is about the (already chosen) decision to absorb early reflections, and how to verify that such goals are being sufficiently achieved.
