The Once and Future Theater - Page 9
post #241 of 490
Wow! It looks much.......... browner smile.gif I can tell that's progress, but it reminds me of the sort of thing that my wife would ask whether it's better or worse than when we started biggrin.gif
Keep up the good work, and keep the updates coming. I don't know about you, but sometimes it's a little tough to stay motivated when there's so much to do, and you only have a little time here and there to work on it.
post #242 of 490
Once that first layer goes up it seems like everything goes a little faster. At that point you really only have to worry about the inside of the room.
However, I will say that finishing the spackling is when you turn a major corner! Once that was done I ha renewed vigor. It's still taking a while but I don't just walk in there and stare for 10 minutes before doing something like I did pre-spackle.
Tim
post #243 of 490
Tim
It's great to know I am not the only one who goes into their room and just stares at it for a while. I was starting to think I was going nuts
post #244 of 490
Shameless bump for no-pics progress report. Now that the holidays have finally passed, and my wife has mostly recovered from her sprained ankle, I've gotten back into the theater for a few short minutes. Some more OSB went up, but it's not worth looking at.
The good news is that I've pretty well scheduled a recurring gig with a friend or two to help build after work on Thursdays. Thursdays because after nine, my wife wants to go to bed and the bowling league clears out of the local lanes - then it's dollar game night! So hopefully I'll be more consistent moving forward, and I'll work on keeping my hook in the right pocket instead of the left.
post #245 of 490
Slow and steady wins the race - or at least finishes eventually.
I've been plugging away when I can, and had a couple soundproofing issues come up - hoping for some feedback.
I put up my first layer of wallboard over the plumbing on the screen wall. I've left openings so that I can make removable plugs so that I have access to the water shut-off for the house and for the waste cleanout, should either of those become necessary. I framed around the valves to make a place to screw in a plug, and kept the cut out portion of OSB to make the plug with. What I need is good advice about sealing the plug to the wall. I'll use at least two layers to construct the plug, and the next layer will be larger so that the edge overlaps and leaves a place to put some kind of seal.. But what kind of seal? Will I need to route or rabbet a groove for the seal to lay in? Any links to materials or some already done? I have the Access-Panel SIM from soundproofingcompany, but there's no recommendations for a seal. Does that mean that a seal is overkill?
The other question is about the drain. The drain pipe runs down, parallel to the foundation wall, and then hits an elbow and goes through the wall. I had considered wrapping the elbow in MLV, but didn't buy any and didn't stop the progress we were making the other day to go to the store for it. Would you remove the OSB that blocks the elbow and get some MLV or forget it?
Here it is before the wall:
And the detail of the opening:
post #246 of 490
I personally don't think that seals would really add that much in terms of a real-world soundproofing difference. With the overlap you have planned with a larger second piece and being tightly screwed to your blocking, there's very little benefit to putting weatherstripping and the like behind the wood panel.
Regarding the pipe, I definitely wouldn't tear everything up for the sake of wrapping the pipe. If everything was open and the pipe was exposed, then maybe. But to tear everything up, it's just not worth it for the extremely limited - if any - soundproofing benefit you would receive.
It would be nice to see some full-room pics of your current construction status!
post #247 of 490
+1
+1
and you guessed it, +1
I had a conversation with John at the soundproofing company where we talked in generalities about sound proofing. My understanding is that high frequency sound can't excite reasonably massive objects, but can pass through small openings. So, you have to make any openings small enough that the sound escaping is too high to matter. Overlapping the seems should do the trick there. On the other end, low frequency attenuation is based more on the average mass of the surface. The heavier it is, the harder it is for the low frequency energy to excite it. So we build heavy walls. Long strory short, see TMcG's post above smile.gif
BTW, I'd love to see your HT reading list! You've been bringing the heavy acoustic theory here lately. I'd like to catch up smile.gif
post #248 of 490
Check out the access cover for my F-20 (link in my sig). Speaker gasket foam and some cap screws.. in your case some wood screws would work fine.
No leaks from my sub, so I think i would work nicely in your application.
As for the pipe, I have the same scenario. I can actually still access mine, but it's just not a priority at this point. I wrapped some adhesive backed rubber around it with no real success (I know it's not designed for the purpose, but I didn't notice any difference). I think Ted sells some stuff for pipes and I believe Big has used dynamat.
Alternate solution: you may only use the bathroom during intermission.
Tim
post #249 of 490
Thanks for the thoughts and link Tim. I'll check out what you did for your subs.
This is probably the reality - on the other hand, I would really like to be able to clean up dinner, start the dishwasher, and go downstairs for a movie while the washer does the dirty work. I hope that's successful.
post #250 of 490
This is different because the box is pressurized and trying to maintain internal pressure unlike an access panel which is just trying to keep the noise out. The wall is not pressurized at all and we are essentially talking about mid and high frequencies squeezing through two layers of OSB bound tightly together. To be honest I think you'll have FAR more sound vibrating through this panel and the whole wall than finding its way through the two layers to escape and ruin the soundproofing. Just my two cents.
Tim
I just talked with Ted yesterday and he no longer sells the pipe wrap which was essentially MLV with an adhesive on one side. It didn't sell because it probably didn't make enough of a difference to merit the cost of the material. So Dynamat, MLV from other sources or similar are your only other options if Fred's really concerned about the pipe noise which I am betting will not be heard when it is locked behind the wall, especially at his seating distance and with all the acoustic treatments, carpet, movement and audio in the room . . . even the quiet passages.
I honestly wouldn't worry about it Fred.
post #251 of 490
I'm a little too ashamed to post any. There's too much mess and too little progress. I'll see what I can do, mostly to keep the thread from slipping into the abyss again - also because I still haven't really roughed in the door and need to document a decision about it, since I don't know what I'm doing and will forget what I learn if I don't write it down where I can find it (here).
post #252 of 490
Here's a source for acoustic pipe wrap:
http://westcoastsoundsolutions.com/pipe-wrap
post #253 of 490
How do you like the Drywall lift? I'm thinking of buying one from Amazon myself. I looked around on Craigslist and didn't see anything promising. Most of them are selling for what you can buy them new for. Home Depot wants $37/day, and I'm sure it's going to take more than one day smile.gif
post #254 of 490
Unless you can get it done in a weekend, I would highly suggest picking one up. Remember, it isn't just the DW. I used it for the soffits and light tray as well. I was a one man operation during that stage (guess I still am), so the lift was definitely a necessity. I was lucky enough to buy one from a friend for $100. Then sold it on CL for the same price when I was done with it about 4-5 months later...rolleyes.gif
post #255 of 490
I'm already thinking I can use it to finish other rooms in the basement. Hadn't thought about the soffits, but that's a great idea as well!
I'm just wondering if the Amazon lift is "good enough" quality to lift 10' sheets of 5/8" DW without dropping it on my head biggrin.gif
post #256 of 490
Yeah, mine's the same one that everyone around here uses. It's not "nice" - the reviews on amazon are spotty, complaining of quality and durability. I'm sure if I was using it to make a living I'd have serious complaints, but as it is, it's totally worth the investment. With free prime delivery, the $50 or so net it will cost me by the time I sell it is money well spent.
It sags and wobbles a little, and the sheet still sags over the ends, such that you're still going to use one hand to hold it in position while on the ladder under the lift, but with a little practice it works as well as is required. The casters roll smoothly, especially on my existing hardwood floors. The legs are wide and stable, but still small enough to get the lift into the corners. Loading it requires some muscle, but is "doable" solo. My only serious wish is that you could use it to hang sheets high on the wall, but lifts (at least in this price range, maybe in any - not sure) don't flip all the way vertical for pressing into a wall (plus the legs would be in the way). So it's not a complete substitute for a second set of hands, but it's close.
post #257 of 490
It will lift 10' sheets (I haven't), but it'll be important that you center them so that the sag is uniform.
post #258 of 490
Well, looks like I'll keep doing my part to keep the economy growing then smile.gif Off to Amazon it is!
post #259 of 490
This is what I keep telling myself. My problem is I can't use the materials as fast as I can afford them. I haven't bought anything in months, but I still have a pile of lumber left to build something with. ...now where did I put my hammer?
post #260 of 490
3 weeks ago I said I needed to figure out my door situation. The idea is that I need to make sure my rough in is right, before I hang any OSB or drywall. I've been working from the screen end towards the entrance end, hanging OSB, and I'm starting to get close, so here's the situation:
There's 40 inches between these two studs. My plan when we set them was for them to be king studs. Doing some reading and shopping, it looks like I'll need to adjust a little. This web article: http://www.finehomebuilding.com/how-to/departments/building-skills/framing-a-rough-opening.aspx says king studs should be door width plus 5 inches. Since doors are sold in 30, 32, 34, 36 inch sizes, something needs to move, or at least shim. The first thought that occurs to me is to double each of these studs, so the new opening is 37 inches. 37 minus five is a 32 inch door.
Is that what you would do? Or would it be better to maybe add a 1" strip to one side to get me to 39 (minus 5 leaves a 34 inch door)? Or do I need to back some of this out and try again with a 41 inch king stud spacing to get to a 36 inch door?
All of this assumes that the writer of that article knows what he's talking about and king studs minus 5 = door. Is he leaving too much wiggle room and I can actually squeeze in a 36 inch door? I assume that a wider door would be better for moving things in and out, but maybe 32 is adequate and I should go with the obvious first choice and double the king studs...
So for those of you who can't tolerate my rambling here it is:
[*] What size door do I need?
[*] What distance between king studs is best for that size door?
post #261 of 490
Also, to appease the photo-whores wink.gif here comes a better vantage on my current messy situation.
First is the left wall. I took the advice given earlier to measure 48 inches down from the ceiling and cut my OSB to fill the bottom, then come behind and hang the top sheets. If my walls were plumb and square that would be easy, but even not easy, this has been a good approach.
Next is the right wall. You can see the same general pattern but less progress. There is some light coming through the open portion, so I was leaving it to later so that I can keep the light as long as possible.
post #262 of 490
I usually work from the size of the door.
30" door needs 32" between jacks, 35-1/4" between kings.
36" door needs 38" between jacks, 41-1/4" between kings.
That's a pretty tight fit, your framing should be pretty darn close to perfect or you will have an issue.
Yes, doors are sold in 2" increments, but 2'-6" and 3'-0" are usually the most common sizes in stock. Of course you can easily order other sizes. Typical in a house is 2'-6", which is why most furniture fits through a 30" opening.
Tim
post #263 of 490
I work from the door size as well. 32" door, then a 34" opening between the jacks. I also like to make sure the hinge side studs are plumb so I can set my door against the jack stud when I set it. Then I can screw the jamb directly to the jack studs. I think it makes it a little stronger. I also like to add a little more horizontal blocking between the king studs and the next stud over. I feel like it reduces flex in the wall when the door is slammed. It's a pet peeve of mine when the whole wall shakes when the door is closed.
post #264 of 490
I am going with a 32" door - the door leading to my basement is a 30" so I am using the lowest common + a few inches - maybe that helps?
I agree with Mr. Tim on the spacing
post #265 of 490
Thanks guys. That helps a lot.
The specifications at lowes and homedepot websites sometimes gives rough opening dimensions. I think I'll go for a 32" door and special order if need be.
Fred
post #266 of 490
Here's a long-overdue response to J_P_A.
First, thanks for the compliment. Though as you and I have discussed, often what passes for informed internet conversation is just wild speculation by someone only partially informed - at least that is how I often feel about my own posts.
I wish I had a specific list of great resources. I only have a few, and there not necessarily great or unique - my general approach has been to read everything that comes up. I spend a lot of time chasing weird stuff. Generally, if I'm interested in theory and best practices, there are two websites that come to mind - the what's best forum, and gearslutz. The what's best forum is great as a resource because you hear directly from industry professionals, and often there are meaningful exchanges among trustworthy sources, so you can really get a feel for what the strengths and weaknesses of a particular idea or technology are. I actually haven't been following ongoing threads there, but I get the feeling that as a community forum, it's a little slow, and may not be long-lived. On the other hand, gearslutz is populated by DIYers, so the conversation are generally more practical (less theoretical) and generally well-documented. The caveats with gearslutz include the sometimes novice posters (both a blessing and curse, as you may have to wade through meaningless misunderstanding, but you may see our own misunderstanding corrected) and the stated bias toward mixing facilities instead of casual listening or home theater.
Of course, the print resources are nice as well. I haven't read more than what are probably recognized as the two most oft-cited around here. Floyd Toole's Sound Reproduction, and Cox and D'Antonio's Acoustic Absorbers and Diffusers. I borrowed these two books, one at a time, from local university libraries - thankfully, I have a close friend who is a university librarian and able to work out the inter-library loans for me. I read both of them cover to cover, except for the math that was not comprehensible to me and seemed irrelevant anyway, in many cases. Toole's book is very readable. It's the best starting point for a novice, IMO. It's complete in its approach, very practical, and well documented. If I had time and easy access to original research, the footnotes would lead to years of great reading. Cox and D'Antonio's book is thorough and important, but less practical. The text is described as practical, in that it refers to real applications and not just mathematical theory, but it has very little direct implications for small room acoustics. If you can wade through the calculus (there is a lot - and I still can't tell you what a wave number is!), you can develop a working understanding of the principles and a good feeling for when and how they might be applied to small spaces - though I usually go to gearslutz to see what a successful implementation looks like.
Other resources include a few blogs and webforums, like (in no particular order) redspadeaudio, the articles Earl Geddes has written and published to his website, and the forums at diysoundgroup.com (see especially Bill Waslo's article about setting up controlled directivity speakers in the articles section). Of course there is also the white paper that Nyal Mellor and Jeff Hedback wrote recently - it is thoughtful and provides a lot of reading and opportunities for more searching. I've been reading more and more about loudspeaker design in the last few weeks. I'm coming around to the idea that thorough understanding of the way speakers make sound will let me see more clearly the way that sound will interact with me and my room. I'll be able to make better decisions about placement and selection once I've read more. Along those lines, I think I'm going to try to get a friend of mine to build me some speakers instead of buying them commercially - probably a SEOS design from diysoundgroup.
I expect that most of this is stuff you have seen already, which is one reason I didn't respond to this earlier, but maybe I'm wrong and this is new and useful to you. Hopefully it's useful to others as well.
post #267 of 490
As part of my new regimen, I'm in the theater more often. I've been treating it like a hobby - doing it a few minutes here and there, as is convenient. I need to be treating it more seriously. I would have liked to all along, but I was trying not to let it change my normal day-to-day home-life schedule. Well that's about to change. smile.gif
So here's a new picture for reference. Axel came downstairs while I was packing up and taking a couple pictures, so that he could find out what all the noise was about.
You can see in this picture of the right wall that I have gotten OSB hung all the way around the corner, almost to the door (which I still haven't changed for rough in).
I this next picture, you can see the way I worked around the plumbing in the front wall. I did it this way figuring that it was the easiest way that came close to leaving no major holes. I knew I'd do it differently for the second layer, so there wouldn't be holes ultimately. I knew it was a weak compromise, but I didn't see the better way.
Here's the better way.
post #268 of 490
Looks like you're getting a nice fit at the wall-to-ceiling corner.
You can always take the piece of OSB you cut out on the first try and secure it to the stud. Usually I drill a hole with the hole saw, then make 2 cuts with the circular saw to free the piece. Then I reinstall that little piece.
Tim
post #269 of 490
Thanks for noticing. smile.gif I've tried to get the corners nice and even. There are a few areas that I'm less happy with, and some other gaps in the middle that will need some attention, but mostly it's pretty tight. Just a few more hours with the OSB and I'll be breaking out the silenseal.
I'm hoping that I can limit this hobby to between two and two-and-a-half years. Right now I'm about 15 months in and hoping I don't have more than 15 months to go. Obviously, I'll need to pick up the pace.
post #270 of 490
Two days in a row! (okay this is not a picture of my progress - you'll just have to take my word for it this time.)
