AVS › AVS Forum › Audio › CD Players & Dedicated Music Transports › getting into high quality music need cd player
post #1 of 7
hi all
i am getting into better sounding music over my mp3s
i am interested in a good cd player but is it worth it?
i have plenty of cds and have most on flac i ripped myself
i am not sure which cd player for under $200 that will be good
any advice would be great
thanks in advance
post #2 of 7
Originally Posted by extrafuzzyllama View Post
hi all
thanks in advance
There are no standalone CD players worth mentioning under $200. It is niche market now, so price is high. For Flac, get Squezeebox Touch (I saw it offered for $230 recently), it has good DAC inside (comparable to any sub $1000 player). If you still want to play physical CDs, do it on your home theater system, using DVD/BD player as a transport. DACs inside most mid-range receivers are sufficient, unless you have multi-thousand dollars speakers. But then you likely won't limit your budget to humble $200.
post #3 of 7
Exactly. Almost the same as my system.
post #4 of 7
in that case i might save up for a oppo 93
post #5 of 7
Great choice!
post #6 of 7
I've had great luck over the years buying used (knock on wood) and recently picked up a used Oppo 83 for about 3 bills.
post #7 of 7
The Oppo 93 is a great choice. It's pretty good for analog audio (if that is your intent) but obviously not as good as the Oppo 95.
