So I'm going to be making my first 12" HT subwoofer. I'm hoping this will really excel at music reproduction, delivering tight, deep, musical bass. I've already purchased the driver and will be buying the amp in the next day or 2.
Driver:
Dayton Audio Reference RSS315HF-4 12" 4 ohm subwoofer
http://www.parts-express.com/pe/show...number=295-464
Amplifier:
O-Audio 500W BASH Subwoofer Amplifier
http://www.oaudio.com/500W_SUBAMP.html
Design:
John Krutke "Zaph Audio" (with slight changes) smaller amp external dimensions. Going for 2.2ft^3 net. f3 will be 36.2 Hz anechoic with a Qtc of 0.76. Driver parameters suggest sealed enclosure is optimal (Quality factor is 49)
Construction:
3/4" MDF, Solid Oak internal braces, butt-joinery with biscuits. Sanding sealer coats internal area. 3/4" homogenous (virgin) carpet padding lines the walls. 1/2" chamfer on all external edges (except rear). May have some custom brass feet made, painted black.
Finish: Mutliple coats of sanding sealer, Roll-on black truck-bed liner. Should be all black and stealthy looking.
I've been looking at some small ported enclosure designs as well, but am strongly leaning in this direction. If anyone has any suggestions or calcs to add I'd welcome that.
Driver:
Amplifier:
Design:
Construction:
