Hello, all:
I've moved into an apartment on the eastern slope of Missionary Ridge in Chattanooga. Not far from the top of the ridge, but on the eastern side.
http://www.tvfool.com/?option=com_wr...4bbaa60ba6c757
My Digitenna DUV-XF is out on the deck, aimed in a southeasterly direction. I get reliable reception out of:
WNGH-33 (18-1) PBS
WSB-39 (2-1) ABC/MeTV
WAGA-27 (5-1) FOX
WGCL-19 (46-1) CBS
WPXA-51 (14-1) ION
(WUPA and WATL are present as well but trampled by local analogs.)
The puzzle to me is that I don't get anything else. Now, I have some partial explanations. I know that I am slightly below the ridge, and I know that the building has some foil-backed insulation in it. I also know that I'm looking through the building at the local signals.
But what's odd is that I have tons of signal from the Chattanooga stations, but nothing decodes. I hooked up my spectrum analyzer and, for example, WELF-16 (23-1) looks pretty strong and very rectangular. Yet my HDHomeRun won't even try to decode it, nor will my analyzer, nor will any of my other tuners. With very careful placement I can often get one or two of them to pop up at a time, but then I lose everything else (except WNGH).
If I go outside and stand at the southwestern corner of the building, all the Chattanooga signals come in fine on my Silver Sensor, even though the signals look essentially the same on the analyzer as they do on the DUV-XF on the deck. On the DUV-XF, I can look at the analyzer and see WSB-39 next to WDSI-40 and see WDSI is about 10 dB stronger (HDHR: 100% strength 0% quality) but fails to decode while WSB is fine (HDHR: 90% strength 75% quality).
I'm really not sure what to do at this point. I've got my Silver Sensor sitting in my bedroom in a position where it gets WFLI, WDSI, and WYHB-LD and nothing else (except WNGH) right now. I'd really like to have the locals available to me without moving the antenna around constantly. I don't mind having a separate aim for Atlanta versus Chattanooga, I just don't want one aim for Atlanta and eight for Chattanooga.
Here's my reception: http://www.rabbitears.info/dxlocation.php?id=265
Anything noted in green I have decoded cleanly in at least one position.
Any thoughts? Any extra information needed?
- Trip
WNGH-33 (18-1) PBS
WAGA-27 (5-1) FOX
WGCL-19 (46-1) CBS
WPXA-51 (14-1) ION
- Trip
