Originally Posted by rob80b
But my original inquiry was from reading LGs paper, it looks like resolution is also a contributing factor, not too sure how this applies to the up-scaling algorithms so my theory could be incorrect.
"[0008] In the PDP adopting the sub-field driving method, the brightness is determined by the display interval, that is, the discharge sustaining interval. Since a relatively long time is wasted due to the address interval allocated equally for each sub-field SF1 to SFn, however, a time allocated for the discharge sustaining interval determining the brightness lacks. For instance, when 480 lines are scanned by a scanning voltage pulse with a width of 3.m in the address interval of each sub-field, a time of about 1.44ms is required. Accordingly, since a time of about 12ms (i.e., 1.44ms×8) is allocated for the total address interval when 16.7ms is allocated for on frame display interval consisting of 8 sub-fields so as to display a 8-bit image data, a time of about 4ms is allocated for the discharge sustaining interval except for the reset interval. As a result, the conventional PDP has a problem in that the brightness is low due to a relative lack of the discharge sustaining interval determining the brightness. Furthermore, when it is intended to implement a screen with a high resolution, a discharge sustaining interval becomes more lack due to an increase in the address interval according to an increase in the scanning lines to make the display itself impossible."
https://data.epo.org/publication-ser...iDocId=4997940
That quote is describing the effect of the number of panel subpixels on brightness. Absolutely nothing to do with source resolution.
They are saying that more panel subpixels means more "time" is required to send data to all of them and thus less time is available to emit light. Since PDPs control brightness via "time" (i.e.- PWM), if there is less time to emit light then the panel is less bright.
In other words they are saying a 480p PDP display is brighter than a 1080p PDP display. Source is irrelevant.
![Disney WOW: World of Wonder [Blu-ray]](http://cdn.avsforum.com/d/da/50x50px-ZC-dadc69a0_B0045ASBLG-51TziBcqZFL.jpeg)
), which is Gamma High, Brightness 54 and IRE5 at +5 -1 -2...
