Originally Posted by rpauls
I checked last night, and to increase the set_down ramp width from 125us to 140us required a very slight turn clockwise.
In my case, here are my approximate before and after settings for up/down in terms of o'clock reference:
Set_UP
original = 12:00, final=3:00 (max clockwise)
This change reduced Set_up pulse height from 350V to 285V (target = 280 for my panel).
Set_Down
Original = 3:00, final = 3:30 (very slight turn clockwise)
This change increased Set_down ramp width from 125us to 140us (target = 140 for my panel).
The above two adjustments reduced my measured MLL from .036 FtL to .008 FtL. I believe all (or at least most) of the improvement was do to the Set_up adjustment.
Rich
Set_UP
Set_Down
Rich
Last night I tried adjusting set_down alone to see if it was contributing to the black level, and it was. Most of the improvement is from set_up, but set_down also plays a role.
As an experiment, I moved it beyond the 140us setting recommended by the manual and the screen got very dark, and then eventually pixel misfires occurred. At the point where the misfires just start the MLL is so low I can not measure it. Too low for my probe, just says 0.000. However the TV is not stable there as bright scenes lead to pixels that get stuck on as some have noticed.
Looking at the waveform, I can see that the maximum I can go before the shape changes is 150us. Adjusting beyond that starts to lift the negative ramp bottom corner off the floor. After moving is about 50V off the floor misfires start to occur. I decided to set it somewhere in between 150 and very slightly off the floor and I measure MLL at .005 now. I may keep it there. Still evaluating. I am guessing that the 140us figure is specified to make sure that the waveform never lifts off the floor even as the set ages or when cold.
So here is what I see now as a function of set_down pulse.
140us MLL = 0.009
150us MLL = 0.007
160us and 25V off floor MLL = 0.005
All of these are for 60HZ input btw. The MLL for 24HZ input is more than double these figures unfortunately and there appears no way to go below about 0.016 without misfires.
![Disney WOW: World of Wonder [Blu-ray]](http://cdn.avsforum.com/d/da/50x50px-ZC-dadc69a0_B0045ASBLG-51TziBcqZFL.jpeg)
