Originally Posted by
rob80b
Hi Bazard,
Have you had a chance to directly compare your current MLL on your PZ950 with the better Panasonics and Samsungs?
Also I'm curious to know for those who have tweaked their panels, when viewing films which are already borderline when it comes to crushing black if the tweaks have a tendency to crush the blacks further and lose shadow detail on those films.
No crushed blacks, at all, on mine after tweaking.
I have followed Turrican's Directions to the tee and am amazed on how unbelievable PQ is, not just deeper blacks, but the overall pics on this TV is mind-blowing!!
One thing though, once in a purple moon, I might get a white pixel or two misfire only upon changing the channel. Going to be hard to know if I fix because only occurs seldom.
What I should do without compromising the blacks I currently have????? Sniff, sigh. Which one could be causing this?
I have VA turned Turned all the way clockwise.
VY is full countercw.
SET_UP was clockwise all the way but had to turn back some due to noise (red and colored streaks)
SET_DOWN...uhhh, don't remember but I tweaked while looking at front of set to also remove some noise in the black letterbox bars.
Also, which one of the 4 is most "responsible" for the deepest blacks?
I thought didn't have to remove back panel again but guess I will have to even though looks beautiful.
Those last few pics I posted which show positions should be DISREGARDED due to having to re-tweak because noticed some of those red dots in MENU SETTINGS of TV only. Will post again once re-tweaked.
PEACE
