AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › Epson 3010 glasses
Epson 3010 glasses - Page 8
post #211 of 365
Originally Posted by Rigby Reardon View Post
How are the Sony glasses in terms of comfort? I'm generally quite happy with the Epson glasses, but they start to pinch a bit above the ears after an hour or so.
The Sony's are tighter than the Epsons. If you have a big noggin, stick with the Epsons. I think someone already mentioned the Sony's as being not as dark as the Epsons. They also have a reflection (at least for me) on the outer edges that's kinda annoying. I'll let my guests (the little headed ones) use them and i'll stick with the Epsons.
post #212 of 365
Is this reflection from a lit room? If I have a fully dark theater, will this be an issue?
post #213 of 365
I guess I do. Thanks guys, will stick with the Epsons for now.
post #214 of 365
Falala..if I buy Monster 3d glasses,can I use them at same time as my Epsons?
I'm seeing some minor ghosting on far distance objects..but see none with medium or close objects.
I'm hoping that I can use both Epsons and monsters at same time.
My wife sees very little ghosting...guess I'm sensitive to it.
post #215 of 365
That's exactly my plan....I will use monster and give epson's to the family.,...it works like charm
post #216 of 365
Falafala: what are the advantages of the Epsons over the PS3s? Is there a reason you would recommend one over the other?
post #217 of 365
If you mean you want to buy additional glasses, then it's worth trying PS3 as they are cheaper, readily available, gave lesser ghosting (on the objective test I uploaded on YouTube) and fit better for younger kids...also you may be future proofing if you plan to buy PS3tv
The cons may be the reflections that some one mentioned...although in my darkened room they were fine
post #218 of 365
I agree with Falafala the Sony glasses are much more snug to me, however my wife prefers the fit of them over the Epsons with her glasses on, she agrees with you on the pinching but for her its right behind the ears. She has said the Sonys are a bit discomforting to her eyebrow seeing how they will fit snugly against that area. None of my kids have any complaints about the fit or comfort level of the Sony glasses. I know for me they are too tight but at the price point and no complaints from the kids and my wife preferring to wear them over the Epsons..its a win win for my budget!
post #219 of 365
I'm planning on buying the 5010 shortly. It doesn't come with glasses and I figure I need about 4 to start. If the PS3s are better and cheaper than the Epsons, I think it may be a no brainer. If I notice a lot of ghosting, I could always pick up a pair of the Monsters for myself.
post #220 of 365
I have total control over light in my space. It could be due to my PJ being ceiling mounted directly behind my sitting position. Definitely can be seen with lights on in the room. It's like those sunglasses that sell as "rear view Spy glasses" where you could see people sneaking up on you from behind... http://www.thinkgeek.com/images/prod...es_closeup.jpg
I also for some reason seem to get more eye strain using the Sony's.
post #221 of 365
Falala...let me see if I'm understanding this correctley.
when I get the monster vision glasses I need to connect them to pj with its on emitter...then switch setting to external emitter.on pj settings.
If this is right then am I to assume that the external emitter will work the monster visions and Epsons too.
Before I place order to buy the monsters ...you did say you eleminated all cross talk/ghosting with monsters correct?
post #222 of 365
NO
monsters need a VESA port which Epson doesn't have
so instead they came up with a brilliant idea of including a tiny IR receiver along with their RF emitter which picks up 3010's IR signal and converts it to RF
I tried two sets of monsters and was able to fairly eliminate the cross talk below my sensitivity level....as long as i am looking though the top portion of the lenses (which turns out to my surprise is nonrestrictive in the sense that its not an issue when sitting but when you are lying down almost horizontally you can just tilt the glasses a little downward to meet this requirement)
one universal advice i have for everyone....buy it from place where you can return hassle free so you have the opportunity to test them to your liking
post #223 of 365
don't take my word for it...buy a pair and see if you like them first
post #224 of 365
Can you make sync adjustments without having to use a computer?
post #225 of 365
Just now occurred to me one more awesome advantage of PS3 glasses
They are designed with a feature called SimulView that allows two players to see two different images for coop game play
How is that good for Epson 3010 ? I think you can engage SimulView to convert 3d image to 2d...this comes in very handy if some one wants to go back to 2d as they may find 3d straining
This is brilliant because it allows groups of individuals to watch the same movie in 3d or 2d based on their own perso al preference !
Simply a brilliant discovery
post #226 of 365
Sorry spoke too soon
I couldn't get this feature to work on COD blackops ps3 game and the tiny manual says the sw should support SimulView....not sure what that means...I assumed that all SimulView is doing is allowing one to pick same image for both left and right....wondering how else they could have implemented this !
will try a movie to see if it works...too bad this could have been a great feature
Found a blog on this...http://www.avsforum.com/avs-vb/showthread.php?t=1368078
post #227 of 365
The Pannasonic 3rd generation/"3D3" glasses DO have this feature. There's a sliding switch at the top that allows one to view something being displayed in 3D in 2D.
Ed
post #228 of 365
Ed
cool...how do they compare with Epsons ? Do they fit younger children better ? also whats the best deal on these ?
thanks
post #229 of 365
post #230 of 365
FYI...Just noticed that the official Epson glasses are currently available for sale on Amazon (actually comes from another store, though). About $86 and as of this moment they indicate that they only have 6 in stock, so they'll probably be out of stock soon.
post #231 of 365
Whats the verdict on Xpands X104 compared to the Epsons. Im in the process of getting a 5010 but projectorpeople are out of Epsons and they said Xpands are better.
post #232 of 365
thanks
They are lighter, smaller and very comfortable--look and feel pretty much like ordinary sunglasses. I haven't been able to detect any crosstalk/ghosting with them. I really can't speak to the fit for kids but I would think they'd be better than the Epsons because of being lighter & smaller--the pair I have are the "3D3MU"s which are classified as medium. If you could find the SU/small ones I would think they'd be ideal. I bought mine just before Xmas from Amazon for $79 and got 'em delivered overnight for $89.XX but I believe they raised the price right after I ordered. Hope this helps.
Ed
post #233 of 365
Ed
i searched for these on ebay and got these.....are these the same ? do these have 2D-only feature ?
http://www.ebay.com/itm/NEW-100-Comp...ht_8085wt_1344
post #234 of 365
Epson currently has a discount code BTB15 that will give you 15% off and if you buy two glasses you get free shipping... Just got the email from them this morning.
Joe
post #235 of 365
Joe
Is this just on the Epson website or an authorized dealer and does it include the 5010 and 6010. Im gona order the 5010 today if I can get it cheaper than the $2699 price everyone has for the $15% off.
post #236 of 365
This is only on Epson website.. I didn't try it for anything but the glasses but I think the projector on the site is retail price so 15% off may not be that great of a price...
post #237 of 365
Yea I just checked and there out of stock for the 5010. Im probably still gona order the 5010 today anyway but a couple places are out of stock on the Epson glasses.
post #238 of 365
Joe
That discount brings Epson's $99 store price inline with what you can get from B&H shipped with 3-day service.
post #239 of 365
Received my order for the Monster Vision MAX 3D glasses and have to say I like these even better than the Xpand X104 YOUniversal 3D glasses. They have a bigger lens, are more comfortable to wear and the lens seems to let a slight bit more light through and have a grey tint, the Xpand appear to have a slight bit of yellow tint to my eyes. I'd recommend the Monster/Optoma glasses for the Epson.
post #240 of 365
NO! I have 2 pair of those and they fit just about the same as the Epsons. Actually, the Epsons will fit snugger when set to the smaller setting with the adjustment available inside the bow near the temple. The Blicks do NOT have the 3D to 2D option and I see ghosting with them that I don't see with the Epsons or Pannys.
Wow, looked up the Pannys on Amazon and they were $40 more than I paid for 'em just before Xmas! I did see a listing there for the small ones that were less.
Ed
