Originally Posted by markm75
So i tried everything, tried plugging the hdmi from the htpc directly into the hlt-6187s.. no change..
I get the blurry double image.. like tron 3d.. the menu, is blurry with overlapping letters where the 3d effect would be.. put glasses on, tried both modes on tv etc.. no sync.. dlp link fail.. verified intel hd graphics set to 60hz..
Only thing it could be now i guess, is the TMT 5 software or the glasses themselves...
So my question is.. is anyone using TMT, or what software player?
mine is 5.0.1.114
And secondly, if its the glasses maybe moving on to another pair, anyone tried these optoma bg-zd101 and know if it works with the hlt6187s? http://www.amazon.com/Optoma-BG-ZD10...ref=pd_sim_e_1
mine is 5.0.1.114
To eliminate TMT as a factor, try watching a 3D video via youtube: http://www.youtube.com/watch?v=0U0ZDjnQiXQ
You can set it to checkerboard, sbs, tab, etc. by clicking on the 3D icon.
I really doubt this is your problem but if you are using checkerboard and resize the desktop using the default nvidia tool it will not work (it scales after applying the checkerboard effect).
I guess the primary giveaway is that your glasses don't sync at all. They should sync regardless of whether or not you have 3D content displaying if your TV is in DLP Link mode. ie. you will see some flashing and discoloration followed by a subsequent stabilization at half brightness. You say the glasses belong to a friend, presumably they work with his set?
Other light sources could be interfering perhaps. Bizarrely the backlight for my wife's laptop generates a DLP like sync signal which interferes with the glasses for example.
