AVS › AVS Forum › Video Components › Home Theater Computers › Netflix HD Streaming
post #1 of 4
Hi,
I've searched, but can't find a solution (though I suspect it's here somewhere). I have an Intel p8400 (dual core, 2.26 ghz) with a Radeon 3650 (512 mb) and 4gb of ram and I'm running Vista 64 bit. My CPU runs at about 2% at idle. Running Silverlight (4 or 5) streaming SD, I'm not dropping frames, though the CPU is in the 80s. In HD, however, I"m getting about 1 fps (1 rendered/20 dropped) and the CPU runs at close to 100%.
Is there any reason I should be having problems streaming HD given my hardware?
Thanks for any help.
post #2 of 4
First thing I would do is turn off power saving, i.e. use the High Performance profile.
post #3 of 4
3650, vista (yikes), my eyes started bleeding and had to stop reading.
post #4 of 4
Wow! Never even thought to change the power settings. That was it. I'm now running at about 50% and not dropping frames at all in full screen HD.
Thank you so much!
