AVS › AVS Forum › Display Devices › Flat Panel General & New FP Tech › What fully realistic 3D looks like
post #1 of 10
I wanted to demonstrate the difference between 3D depth in movies vs. 3D fully lifelike 3D depth seen in games. I also wanted to show how 3D's immersive characteristic has potential for practical use by mainstream users and I finally figured out a reasonable way to do it: by using a realistic looking PC game. Having played games using realistic 3D, i think it can be along to a wide variety of, perhaps, non-casual viewings, like when your going to sit down and watch a show on PBS for a solid hour. To get right into it... i mentioned elsewhere that i watched a show on cathedrals that you can watch here if you want.
That show and another show on medieval arches i remember, both featured very nice interior shots in HD. If you've ever walked into a large church or stadium and looked up and went "wow", then you might surprised what full 3D can do to more mainstream TV shows. Below is a video of an old church, taken within one of the most realistic looking games yet, called Metro 2033, to give an idea of the practical benefit and potential of 3D use.
To see it correctly, you'll have to get close enough to the TV to give yourself about a 75 degree field of view. So with a 46" TV, you'd be about a meter from the TV.
EDIT: Iv'e changed all the videos to this one, which has a wide variety of scenery to demonstrate how movies would benefit.
Examples of other content that could benefit from full 3D are shows on cave systems/, scuba diving/sea life, cellular structures, statues, ancient structures, air-craft carriers, flying, climbing, auto/motorbike racing, stunt riding, surfing, etc, etc. There another video with some action too if interested and i'll be uploading more at some point.
To see it, you'll need an internet connection on your 3DTV or load the video onto a usb disk and insert it into the TV. Make sure you have a usb port first. You may also want to turn the TV on and put on motion interpolation or something to warm it up, which should reduce crosstalk.
Unfortunately the detail loss in the youtube video greatly reduces the tangible feeling that HD + 3D has. The original videos were 2GB, compressed, then compressed down to 600mb, then compressed [and annihilated] by youtube.
Edited by tory40 - 4/6/13 at 10:54am
post #2 of 10
Heres another video demonstrating realistic 3D using the very well written game, Mass Effect. Its an older game and the graphics aren't quite as good, but the video is 10 minutes long and gives many more examples of the potential realistic 3D has for scenes in immersive movies.
Unfortunately i didn't have sophisticated editing software to work with and there are no transitions, but this video is has many more types of scenes to give more of an idea about how various scenes in movies might look:
Edited by tory40 - 4/6/13 at 10:12am
post #3 of 10
It's difficult to do and hurts your eyes after a couple minutes but if you do not have a 3D tv and/or are viewing this on a computer monitor like myself, you can still get the 3D illusion without glasses. Select your resolution and full screen the video. Position your head center with the screen and decently close (i went 1ft from a 13" screen). Stare at the middle of the screen and then cross your eyes. Try and align up an object from both videos in the center. Once you get them aligned, your eyes will naturally lock and you can watch the video without many problems (except fatigue). Your eyes may undo every now and again, but it's pretty easy to get them back aligned. Voila, 3D.
*Don't do this for longer than a couple minutes
**Not responsible for your eyes getting jacked up
post #4 of 10
I tried playing GOW3 in 3d. total fail for me just couldnt handle it
post #5 of 10
Total fail for me too, but Gears of War 3 is not a good example of 3D in games because it does not have fully realistic 3D. It uses a semi-accurate conversation process that gives some limited depth at the cost of some artifacts. A few other console games use this method, such as Assassin's Creed: Revelations and Batman: Arkham City.
post #6 of 10
Originally Posted by maygit View Post
It's difficult to do and hurts your eyes after a couple minutes ......
The cross-eye technique is definitely difficult to do, especially at first and moving images don't help. It also doesn't scale the image for you. I've done it here and there enough now where i can instantly focus and move my eyes around the screen, but that took a long time to do.
post #7 of 10
Here is another example of realistic 3D that causes your eyes to stare into the scene at proper realistic angles. This time i wanted to show the effect it has on heights and the sense of danger it can lend. I ended up recording more of this game than i intended and the "sense of height" bit is near 6:50 and on...
If a mod wants to move this to the 3D section, feel free.
Edited by tory40 - 4/6/13 at 10:56am
post #8 of 10
Mass effect looked great on the LG6500 I honestly just played through it a few weeks ago and 2 in preparation for 3.
What exact system are you using because I can imagine the original source would look better.
post #9 of 10
Yeah, the original source looked ten times better. The difference was so great i made a thread about the importance of clarity in 3D presentations. My system is a gtx 570 with a 2600+, but i must run at half resolution, aka side-by-side via Tridef drivers due to HDMI port processor limitations.
post #10 of 10
The problem with creating video content like this, is you can't give the viewer control over the paralax. Without knowing size of the screen and the distance the viewer is sitting, you (the content creator) can't know the max parralax to use (max must be distance between the viewer's eyes as a percentage of the screen width). If you want to make objects at "infinite distance" (eyes pointed strait forward with no convergence) you need to make the object in each viewport exactly at a paralax equal to the distance between the viewers eyes. Without knowing the screen size and sitting distance, how could you do this? If the viewer has a giant screen and sitting very close, your distant objects may need the viewers eyes to diverge - not comfortable.
Games which are rendered in real time, can give the viewer some control over paralax to make it work for their display size/distance.
Movies offer the viewer no such control, so how would you overcome this, by asking the viewer to sit at a distance according to some sort of calibration screen?
