AVS › AVS Forum › Display Devices › Display Calibration › Calman DIY and Radiance Interactive Help
post #1 of 26
I just upgraded to Calman 4.4 and I went ahead and bought the Interactive add-on. I also purchased a Radiance XD from Spectracal and it included the USB to serial converter. I have used the converter before when I upgraded the firmware on the XD and it worked flawlessy. I cannot get Calman to connect to the XD as a source or display. Here is my method that is not working:
1. Laptop is on with Calman 4.4 loaded
2. Load the Radiance Interactive Workflow
3. Connect the USB converter
4. Connect straight-through RS-232 cable to XD and laptop
5. Power on XD
6. Go to Settings tab and select Source
7. Select Lumagen Radiance from drop down
8. Click connect
9. Status bar indicates that it is looking for the Radiance.
10. Error window pops up. It says "Error Number: 9 Source not found. Check your USB, RS-232 or Socket connection.
11. Go to Display control.
12. Select Lumagen again
13. Another error message of some sort. I forgot what it said.
I've tried with a null modem cable as well and the error message popped up immediately, so I'm assuming a straight serial cable is correct. Is this not working because I have DIY and not the Expert version? I am running Windows 7 64 bit. The USB-Serial convertor shows up in Device Manager as COM3. I have tried manually selecting COM3 in Calman and using the Auto setting. I have the License information entered in correctly also.
Somebody help me with this because it is frustrating the crap out of me and the Interactive license cost me 99 bucks and I want to use it!
Jeff
post #2 of 26
Jeff,
The only thing I can think of is make sure to have everything connected and windows find it before you start CalMAN. I had issues with Calman not finding my Runco Q-750 or my i1-Pro. I closed Calman connected everything waiting for windows to do its thing THEN opened Calman.
Also make sure your baud rate is correct for the Lumagen and you have parity set correctly. This can also be an issue if the lumagen is 9600 baud and you have the USB to serial at 19200 or something other than a supported rate.
Hope this helps otherwise you might need to call in on Monday.
post #3 of 26
Thanks. I'll give it a shot. Baud rate is 9600.
Parity = none
Flow control = none
Data bits = 8
Stop bits = 1
Does all that look like what you have? Also, do I have to have the Expert version or is the DIY going to work with this license?
Thanks, Jeff
post #4 of 26
I agree with David. You should have all your peripherals (meter, display, etc.) on and connected before loading CalMAN. Especially anything that is connected via RS-232. Also, as he mentioned, your RS-232 port settings are critical.
post #5 of 26
The port settings are what I was concerned about but there are some settings that I'm not sure about. Those seem to be the default that I posted above. I've tried some different combinations and still no luck. Reinstalled drivers and no luck. If anyone has any thoughts or ideas they would be appreciated. Probably going to have to call on Monday but would like to fix it here. Thanks
post #6 of 26
You have to connect twice to do interactive, once as a source and once as a display.
For the source you should be able to use "auto" for the comm port.
For the display you need to specify the comport, but if you've connected as a source first, the source status will display the comport.
post #7 of 26
Did that work? Everything looks like what I have.
post #8 of 26
No. Not sure what the problem could be. I couldn't get it to work in 4.3 either. I upgraded to 4.4 in hopes that would fix it.
Sotti, I tried to connect as a source first and it wouldnt connect. Is there something on XD that needs to be configured for the RS-232 port to work? I find it odd that you need a null modem cable for firmware updates but a straight cable for this application. It seems like there is something very simple that needs to be configured or checked off or unchecked that I'm not doing. This kind of stuff drives me crazy!!
post #9 of 26
Could be the cable, whatever the cable type that works for firmware updates is the cable you use for interactivity. I can't remember what type of cable is required, but if a null modem works for firmware updates, then it is a null modem cable.
post #10 of 26
Then that may be the problem. On the drop down menu in Display settings in Calman, it actually states "straight female to female "RS-232". I'll give it another shot and post the results.
post #11 of 26
Same error message. There are some RS-232 settings in XD but I'm assuming those aren't needed to get this to work. Thanks for the help guys. I guess I'll just make the phone call tomorrow so maybe someone can walk me through it.
post #12 of 26
It worked! Did a factory reset (again), and this time it connected right up. Mother of God, it f-in worked. It does say in the display control drop down to use a straight cable but the null modem that shipped with the unit is what worked. Thanks guys.
Jeff
post #13 of 26
Jeff
Awesome!
Have fun calibrating
post #14 of 26
RS-232 cables come in many types the most common are straight through and crossover also called null-modem. Then we have the male and female ends. In most cases a cable that has a female and male ends is a straight pin for pin. A cable that has female on both is a crossover used for connecting two computers. But you can also have a straight through with female on both ends like the one used with the Radiance.
Personally I use a female/male straight through cable. I also have a straight female/female adapter and a crossover female/female adapter that way with those three pieces I can hookup just about anything.
post #15 of 26
Derek,
The one that shipped with the unit is female-female crossover. Because of that particular drop down menu in Calman that stated "straight female to female", I went and purchased a female-female straight cable and I couldn't get it to work. I don't know if I was doing something wrong, or if misunderstood what the software was telling me to do. Either way, I finally got it to work. I got a $6000.00 projector from AVS (Sony VPL-VW70) for $1300.00 and a $4500.00 video processor for a song from you guys. With an i1 Display 3 and Calman, the image is absolutely stunning. I calibrated the Sony first, and then the Radiance. Here are the results:
The first few screen shots are calibration results with the Radiance acting as only a pattern generator and with no processing
Sony VPL-VW70 Pre Cal
Sony Gamma
Sony Grayscale Cal
Sony CMS Cal
This is the cal with the Radiance using the interactive mode in Calman
Radiance Grayscale and Gamma
Radiance CMS
Radiance Post Cal
Without the Radiance in the chain, there was so much red in lower end of the grayscale I could easily see it. The 10% window was not even gray. It was a deep burgundy color. I was definitely concerned with that. As I was calibrating the Radiance, I could see the test pattern windows actually go from red to gray. It was really cool. And with the interactive add-on, it obviously happened really quickly. The Radiance is the audio equivalent of adding bass traps to a room. It makes a good system a great system. Derek and Sotti, you're company's product makes a great system a reference system. Well worth the money.
post #16 of 26
i agree, calman is great software to use.
it appears you might be able to a little better on your gamut though. your screen shots dont show that you have "interactive" activated in the cie chart. in the cie chart, you can click and drag the individual colors right inside the target points. you should be able to click and drag the luminance levels of your secondaries down to zero as well.
post #17 of 26
These reports were saved on my laptop. The cal was done the day before, so when I posted these screenshots the meter or the XD were not connectedto my computer. I just opened up the saved workflows in Calman.
I followed the instructions in the Workflow for the CMS calibration. It stated to drag the primaries on the CIE chart where I wanted them and then adjust the Luminance to the correct level. It specifically said DO NOT go back and adjust the location on the CIE chart. According to Calman, Gamut Luminance is the most critical adjustment for the primaries. It said adjust Luminance down to zero and then adjust the CIE chart, and do not readjust Luminance for the secondaries. When one gets adjusted, the other moves around. The DeltaH and DeltaL are about as good as it gets for the goals I was trying to achieve. Of course the goals I was trying to achieve are the goals Calman told me to achieve so I'm assuming I'm right. Of course, I'm fairly new at this video calibration thing, so I'm not speaking with 100% confidence.
post #18 of 26
feel free to adjust the luminance on the secondaires.
post #19 of 26
the CMS controls inside the radiance and duo paired with calman is incredibly powerful. You can get near PERFECT color with them. go iinto the properties of the cie chart(right click on cie). then hit the checkbox for "auto zoom". from there you can drag your color points inside the box and get better results for your primaries.
post #20 of 26
Thanks for the tip. Didn't realize you could auto zoom the CIE chart. I'll give it a shot.
The instructions are incorrect then? Either that or they are there for beginners, I'm assuming? Either way, that's odd. On the Standard workflow, the CMS cal is before the grayscale cal. I was under the impression you couldn't get a proper CMS calibation without proper grayscale tracking. I always do the grayscale cal first anyways but I found that somewhat strange. I'm not trying to pick apart the software, because these are easy workarounds but I find some of the instructions a little quirky for a newer guy like myself. I guess its Spectracal's way of telling me to sign up for the training class in Houston. I least that's what I'll tell my wife. If my thinking is off on the order that the workflow has me going in, then please educate me. I ran through another complete session last night and got better results. I calibrated the CMS and then adjusted the color decoder on the dislpay. Then went and opened up another tab on the CMS screen and fine tuned it a little more. The results were better than the screenshots shown above. I'll fine tune the secondary luminances tonight.
Jeff
post #21 of 26
yep your right.....i just checked the standard workflow and it does show the CMS before the grayscale. honestly, i think this might be a whoopsy. From what ive read and learned, you should always get your grayscale/gamma as close as you can, then do CMS work(like you mentioned). if you had to make alot of adjustments to your primaries, its good practice to go back and make another grayscale run to verify its still good. ive found out in the past that if your primaries needed alot of adjustment, then your grayscale/gamma might be out a whack a bit and needs to be tweeked to get it straight again.
post #22 of 26
THX likes CMS after grayscale, ISF likes CMS before grayscale. Even the experts don't agree.
Just to give a quick runthough for calibrating a display with a radiance this would be my order of operations, and I do have a radiance in my personal setup.
Display:
Best mode, best color temp
sharpness
brightness, contrast
Set closest gamma setting
calibrate whitepoint at 100%
calibrate cuts at 30%
recheck brightness, recheck contrast
recheck 100%
recheck 30%
put gamut into widest mode the current setting allows.
Now radiance workflow:
Autocal grayscale
manual touch up
Autocal gamut
manual touch up
Also we worked with Jim Peterson at lumagen to develop a workflow specifically for the radiance.
http://store.spectracal.com/workflows
post #23 of 26
Display:
sharpness
calibrate gains at 30%
recheck 100%
recheck 30%
Autocal grayscale
manual touch up
Autocal gamut
manual touch up
Sotti,
What do you mean by calibrate gains by 30%?
thanks,
Jeff
post #24 of 26
Sotti,
thanks,
Jeff
I'm was refereeing to the RGB low controls which could be RGB Low, cuts, offset.
There are about 5 different naming convention for the RGB controls.
Adjust the high ones at 100% (109% if possible) and then adjust the low ones at 30%
Assuming you have 2 point in the TV, with one point, just do 100%. If you have >2 point, then just do them all at their specified level.
post #25 of 26
Ok I understand what you meant. I always thought that you adjusted the high end at 80%. Apparently I was mislead. Why do you prefer 100%? Is that because it affects every aspect of the grayscale from 0% to 100% more so than just adjusting the 80%? Educate me.
post #26 of 26
When you have just two points of control you try to optimize the entire range so 30 and 80 are appropriate.
When you add a video processor to the mix, you want to minimize the processing a processor has to do. By getting 100 dead on in the display the video processors 100% can also be set to 100%, 100%, 100% maximizing the range of the processor and hopefully minimizing the amount of processing required
