Frankenstein Theater Project - Page 5
post #121 of 271
Current state, can't believe how much it's progressed compares to the original photos I posted at the start of the thread
post #122 of 271
From the stage:
post #123 of 271
His name is......
post #124 of 271
Front row testing.
post #125 of 271
Stereoscopic, chair mounted projector disguised as a cat?
post #126 of 271
That's the post that you choose to reply to, seriously?
post #127 of 271
Further front row testing, 9.5' from a 133" wide (153" diagonal) screen:
post #128 of 271
Not exactly HT but video related and it did involve a bunch of tools and swearing....
post #129 of 271
Well it's a bit of an improvement, at least it won't all fall over in the next earthquake.
post #130 of 271
All I achieved in the HT this weekend.......
post #131 of 271
Lol
post #132 of 271
Wider view.
post #133 of 271
So after measuring and re-measuring I went back to the projection calculator at Projector Central and I've realized what's happened, the throw range (15') is the limiting factor, the widest image I can project at that distance with the AE4000 is 133".
Given that the curtain wall that the projector is mounted on and the screen wall aren't moving, I guess I've built a CIW.
Anyone have any thoughts?
post #134 of 271
Given that the curtain wall that the projector is mounted on and the screen wall aren't moving, I guess I've build a CIW.
dont go all the way to max, youll need a little extra zoom to play with to get the image right. Id recommend 6" buffer......
post #135 of 271
Darn it, I'm already kind of disappointed that I can't get a wider 2.39:1 image.......
post #136 of 271
Temporary screen & screen wall fabric v3:
post #137 of 271
Light control and curtains.
Here's the current state of the room, there are three openings back into the house, the main stairs window, the straight stairs opening (that connects to the riser) and the wavy stairs opening (at the back of the room that leads behind the bar).
post #138 of 271
So I think the next area I need to tackle is controlling the light into the room, as you can see from the above post there are three ares that light is mainly entering the room (the rear wall doors & windows are covered by blinds).
Does anyone have suggestions about material for curtains to cover them?
1) The main stair window:
This should be relatively straight forward (although it's an odd shape) as I can make a curtain (and fittings) to cover the opening).
2) The straight steps entrance:
This connects to the riser, I think the curtain should be at the top of the two remaining steps as then the light in the ceiling will fall within the HT but I'm debating building a fabric covered panel to cover at lease the first couple of feet as then I can install a fan in it if I need to improve the air circulation (the HT currently has two HVAC input registers but no return).
3) The wavy steps entrance:
This is similar in that there's a light above the steps again but I might just go for floor to ceiling curtains as trying to build an "s" shaped fabric panel at the top to match the shape of the stairs would be a real pain.
Any suggestions are welcome (although I'm not going to sheet rock any of the openings) as currently the light leaking into to room means we only use the HT in the evenings and with the days getting longer I want to address this next.
post #139 of 271
Thunderstorm is directly overhead, just unplugged all the HT stuff not connected to a UPS.......
post #140 of 271
Don't count on a UPS helping much with a lightning strike. I would disconnect everything.
post #141 of 271
Front row installed, awaiting unicorns
post #142 of 271
More curtain related images, focusing on how long the blinds need to be and how to build an 'S' shaped curtain rail to match the contours of the wavy steps:
post #143 of 271
Needed more power outlets so decided to add another PDC, this time with lights:
post #144 of 271
Finished the blinds on the staircase window:
post #145 of 271
Straight steps curtains:
post #146 of 271
Is that light leakage killing your picture? Any stray light is very distracting in my HT (with my admittedly dim JVC RS2)
post #147 of 271
It's getting better with each of the openings I block. and the Panasonic AE4K is a pretty bright projector. I know I need to go back and block the light at the top of the blinds/curtains but I'm just dealing with the big light issues.
post #148 of 271
If the light bleed through the material becomes a problem, then you might want to think about replacing those curtains with something thicker. I've done a lot of work with theater drapes for musicals, and those things are almost like a heavy quilt and have a velvety texture. Nothing gets through them.
Something like this might be a good option (though kind of expensive).
http://www.overstock.com/Home-Garden/Signature-Warm-Black-Velvet-96-inch-Blackout-Curtain-Panel/5740481/product.html?cid=202290&kid=9553000357392&track=pspla&adtype=pla&kw={keyword}
post #149 of 271
Thanks, the current ones are from Ikea, cost $35 a pair and are as much a proof of concept, if I keep them I might just go to JoAnne's fabrics and get material to line them to improve the light blocking but it's a moot point until I block the last opening - the curvy steps one.
post #150 of 271
Wow, I take some time off for back surgery and suddenly it's 7 weeks since I've done anything to my HT!
