Frankenstein Theater Project - Page 9
post #241 of 271
So a good friend gave me a car load of acoustic panels (the triangularish ones) and bass traps, all I need to do know is work out where to put them........ smile.gif
post #242 of 271
post #243 of 271
So I have 16 of the red/tan panels, 6 x 1/2 round bass tubes, a bunch of foam diffusion panels and a curtain wall to fill with pink stuff.
I hope this makes a difference but to be honest I've not noticed any real sound problems except when I get the subs too high and they make the entire screen wall vibrate. wink.gif
post #244 of 271
Sealing for light leakage and installing back wall bass traps and wall insulation.
post #245 of 271
Back wall covered and 1/2 round bass traps added at the sides and below the sub drivers.
post #246 of 271
post #247 of 271
First set of 4 panels mounted on side wall.
post #248 of 271
Second set of 4.
post #249 of 271
post #250 of 271
1) UPS batteries
2) 2nd pair of side surround speakers
3) Far wall matching stub wall panels
4) Screen wall curtains.
5) Bar lighting
6) Stage lighting
7) Complete Insteon setup
8) Bass trap(s)
9) Bar stools
post #251 of 271
Installing curtain wall sound insulation:
post #252 of 271
^Very nice work.
The space inside false walls is a commonly underutilized area for acoustic treatment.
If you have any extra material in the end consider filling the false screen wall also. Spaced off the wall that far will work very well as a broadband treatment on you length modes.
post #253 of 271
Originally Posted by Brad Horstkotte View Post
I'm going to go with FlexRAID (snapshot "raid"), we'll see how it goes
So how's your experience with FlexRAID going, it looks like most of my UnRAID problems were being caused by the old chassis I was trying to use, the new one works great. smile.gif
post #254 of 271
Originally Posted by NicksHitachi View Post
^Very nice work.
Good idea, I'll see what I have left, unfortunately it looks like my screen wall is 24" studs too so it won't be as easy as I'd hoped (the insulation is 15" wide).
post #255 of 271
I was planning on covering the fireplace and installing the fourth set of panels over it to hide it but now we've taken a good look at the fireplace it looks like we're going to leave it as is.
post #256 of 271
The comedy of errors continues, guess what I found when I was drilling to install the cable for re second set of surround speakers......
Turns out it's a structural column so the wood underneath the Sheetrock is 4-6" thick, I haven't the remotest idea how to find my fishtail/wire guide that's somewhere in the wall.
post #257 of 271
Gave up on my nightmare pillar an decided to install the other wall 2nd side surround speaker. Of course that one wasn't straight forward either as there's horizontal framing inside the wall because of the fireplace which prevents me from running the speaker cable inside the wall to the level of the speaker but the accoustic panels mask the workaround.
post #258 of 271
Fuller shot of side wall:
post #259 of 271
Turns out my fishtail isn't in there somewhere, it's inside a completely different column 6' away, I drilled through the floor from the basement into the wrong column................!
post #260 of 271
post #261 of 271
Finishing curtain wall sound treatments.
post #262 of 271
1) UPS batteries
2) Screen wall curtains.
3) Bar lighting
4) Stage lighting
5) Complete Insteon setup
6) Bass trap(s)
7) Bar stools
post #263 of 271
Front corner bass trap:
post #264 of 271
Rear and side wall acoustic panels:
post #265 of 271
Continuing the red theme:
post #266 of 271
1) UPS batteries
3) Bar lighting
4) Stage lighting
post #267 of 271
Stage lights (part 1):
post #268 of 271
Stage lights (part 2):
post #269 of 271
1) UPS batteries
3) Bar lighting
4) Complete Insteon setup
post #270 of 271
Colors - Reds: To match or contrast the accoustic panels, that's the question......
