Frankenstein Theater Project - Page 2
post #31 of 271
Not sure I follow - do you mean 24" OC stud spacing, or 24" between false wall and back wall, or ?
One doesn't usually use OC703 for insulation (in the wall) - rather, for acoustic absorption (on the wall).
I meant 24" stud spacing, there'll be 1-2" between the screen wall and the wall behind it, should I plan on covering that hidden wall with OC703 as the window will be filled with either polystyrene or OC foamular panels?
post #32 of 271
Two points/questions on your material lists:
You call for fir framing material. I'd use "white wood" (spruce or pine) everywhere except for the joists that are only supported at the ends. Fir is more expensive and has a tendency to split. There is no advantage except on the joists where the stiffer material may be better. Even that is doubtful since the spans are so short. Personally, I'd use pine everywhere.
How do you plan to attach the cabinet grade oak decking to the stage? It may be easier and more economical to use structural plywood and overlay thinner oak with glue and finish nails.
post #33 of 271
So I just had an interesting Thanksgiving (hope you all did too )
Net result is I've had the go-ahead to start construction and we have a 3-4 week window to complete it so (as long as it goes to plan - how often have we all heard that before!)
Looks like December's going to be an expensive (and hopefully rewarding) month
post #34 of 271
Ran through the plans again, following updates:
1) Riser will now be extended to replace the bottom step tread, this will make it even stiffer and remove the problem of what to do about the join/gap where it met the bottom step.
2) Screen wall is now 6" taller as I'd missed the 7" screen border when measuring for the screen.
3) Curtain wall will either be extended or I'll mount the projector off the bottom of it so that the lens is within the top edge of the screen.
post #35 of 271
So here's my initial rough plan on how to treat the room, in addition I have the curtain wall which will come down 3-3.5' from the ceiling above the bar which I need decide wether to fill with 2" or 4' OC 703.
My plan is to do behind the screen wall and the curtain wall during construction and then add the other afterwards as required.
Does anyone have any thoughts?
post #36 of 271
Originally Posted by Expat444 View Post
So I need to decide what to use to fill the window spaces that will be behind the screen wall (which will be lined with 1" OC703), I was thinking of using either thick polystyrene sheets from HD or I just found that they stock OC Foamular F-250 http://www.homedepot.com/webapp/wcs/...62&R=202085962
What does everyone think?
Any opinions on this as I'll be doing the install next weekend (all going well!)
post #37 of 271
So looks like I'm in for a fun weekend!
post #38 of 271
Nice haul!
post #39 of 271
Nice haul!
Thanks, in case you were wondering, this is what was underneath the Triads.
post #40 of 271
post #41 of 271
Screen wall and power.
post #42 of 271
Sub-panel finished.
post #43 of 271
Building Rack 2:
post #44 of 271
Holy Moly you've got some serious Apples there.
post #45 of 271
Thanks, that's one of the reasons I'm running two separate racks as I don't want the HT sounding like a data center.
post #46 of 271
The perils of new technology, I was derailed by the new amps and speakers, good job the projector is still in its box.
post #47 of 271
Guess who found their stud finder
post #48 of 271
Anyone have any experience/opinion about this stuff, otherwise I'll install it tonight/tomorrow.
post #49 of 271
Decided to go with dual layers of 2" pink foam and 1" silver faced polystyrene.
post #50 of 271
Installation day 2, screen wall finalized and stage installed.
post #51 of 271
Curtain wall and ceiling reinforcing.
post #52 of 271
Day 3:
Curtain wall framed out.
Riser and bar installed.
post #53 of 271
You're making good progress. Is that Pizza in the second shot, on the bar?
I'l still bury the fireplace. Do you think you'd ever use it? Looks too close to combustible surfaces to be safe.
post #54 of 271
Oops yes it was, all gone now
Still not sure what to do about the fireplace, we've just ignored it for the moment (we've never used it), depending on how it goes when I install the fabric panels I'll either leave it exposed or just panel over it.
post #55 of 271
Window plug finished.
Not sure what to do about the top windows yet.
post #56 of 271
Building rack #1.
post #57 of 271
Screen wall speaker install.
post #58 of 271
It's Alive!
Well rack #2 is anyway
post #59 of 271
Rack #1 up and running.
post #60 of 271
Running wiring for the screen wall.
