Originally Posted by
Mattohio77
I was looking to purchase the RF-7 II home theater system...My question is, can I power this with my Yamaha RX-A1000 receiver, or would it be best to upgrade my power source? If that's the case, I am going to have to take the next step down to the RF-82 II system. I was thinking about the Goldenear Triton II system, until I read this thread. I am going to stick with my original plan
Thanks in advance.
I wouldn't step down the to the RF-82s regardless and I don't have direct experience with your Yammi (looked at online specs), but feel it
could power the RF-7II/RC-64II in a small to moderate size room, especially if you run them as small and cross them over at 80 Hz. That said, if you decide that you want to play material louder, then be on the lookout for a two channel amp but you may not need one. Fwiw, in my experience the speakers tend to get bright when you start to overdrive them and that would be the clue not to turn it up higher.
{EDIT: Your best bet would be to find a place that has the RF-7ii/RC-64II and audition them with a similar AVR..It won't sound exactly the same as in your room but at least if would give you an idea}
