AVS › AVS Forum › Gaming & Content Streaming › Home Theater Gaming › HTPC Gaming › Whaaaaa? RAM not being used.
Whaaaaa? RAM not being used. - Page 2
post #31 of 34
Update to my Update (happier update) ----
I pulled out all the RAM except 1 stick and got everything to boot properly. I concluded, I have a bad stick just need to find out which one.
post #32 of 34
Pull out all the ram and put a single stick back in. Does it boot? Find the jumper on the motherboard that clears the CMOS. Does it boot? Plug the monitor in to the onboard GPU. What happens?
EDIT: I was reading the thread when you made your last update. smile.gif
post #33 of 34
At that [all the above] point I'd also look at BIOS versions & what they fixed & flash back/fwd -- at least before you determined it was a bad stick.
I'll be running memtest & spinrite on my new laptop before trusting it. I have a hard time trusting HDD after my Macbook had a lemon.
post #34 of 34
Did you pull all of the ram out except for 1 single stick and see if it will post?
  Back to Forum: HTPC Gaming
