Originally Posted by MStanic
Thanks folks.
So just to confirm toofast68, as you have yours mounted the way I would be mounting mine. You are using the flush mount that came with the projector and from the ceiling to the bottom of the projector is around 9 and 1/4 inches give or take a couple of mm's at most? If so this will work for me.
Any of you debate the Panny 7000 over the 6010?
Thanks folks.
Yes, that is correct... 9 1/4 give or take a bit to the BOTTOM of the projector.
I did review the Panny 7000, but choose the Epson. Thought the Epson had a better package, with 3D glasses, killer mount, extra bulb, wire cover (which makes a HUGE difference)...plus the 6010 was a bit brighter calibrated than the 7000.
