I got my 6010 with the mounting bracket, extra lamp and additional one year warranty locally from Shear Systems in Metairie/New Orleans, Louisiana. I like to support local vendors whenever possible.
The 6010 has so many lumens I am seriously giving thought to replacing my 10' Stewart Filmscreen Studiotek 130 with a 13' or 14' (diagonal) new Stewart screen - possibly one with their 3D compatible materials. How do I know it will support a screen that large? At 17.5' from the screen I zoomed the picture size to near max and the portion of the image bleeding off the screen onto the (beige) wall surrounding the screen is still very bright and this is while the lamp is set for econo mode.
This is by far the brightest non-commercial grade projector I have ever had in my home (not a bat cave) theater and I will finally be able to "light up" nearly the entire wall with excellent high definition 1080p video.
After setting it at near max zoom and getting an approximately 14' image and then backing it down to the 10' on screen imageI have had for the last six years I felt like I had moved from a movie theater back to watching a very big TV set.
I was far more submersed in the 14' image (sitting at about 15') than the 10' image (at the same sitting distance). With the 6010 we have a pro class projector that can give a real home theater, very large screen experience plus it is backed up by a solid company with a three year unit exchange warranty. Panasonic only has a one year warranty and the unit has to be sent back to them for repair. When I had Panasonic projectors on two different occasions it took three weeks to get them back.
Have not tested the 3D yet. Need to do a bit of rewiring to get that working.
The 6010 has a LCD panel pixel alignment function. I checked it out but the panels are so darn well aligned I didn't bother with adjusting it.
More later.
More later.
